Author Topic: 76 RM250/370A rear brake plate  (Read 14284 times)
« on: June 28, 2015, 10:27:34 am »
Looking for a rear brake plate for a 76 RM250/370 for 15mm axle.
codrington307 at h0tmail d0t c0m
Offline micko
Re: 76 RM250/370A rear brake plate
« Reply #1 on: June 30, 2015, 06:57:33 pm »
I may have one, will check tonite
« Reply #2 on: June 30, 2015, 07:16:33 pm »
Ok thanks.
« Reply #3 on: June 30, 2015, 07:53:54 pm »
I possibly have one as well but have no idea how to identify. Any clues?
« Reply #4 on: June 30, 2015, 08:05:57 pm »
I could probably tell from a photo but i am probably about as clueless on them as you are. It will have a lug for brake cable, 15mm axle, 150mm brake shoes. 77 will be for 17mm axle. Since its from a non ADR bike it may not have 'wear lining limit'? Its a guess.
« Reply #5 on: June 30, 2015, 09:20:50 pm »
It does actually have the wear limit indicator on it
« Reply #6 on: July 01, 2015, 10:11:02 am »
Found 2. One is stuck in a hub which has corrosion, it looks good but not sure if I can get it out without damaging it. The other has had the cable lug repaired but it's a decent repair & once painted no-one would know. Send me your email address again please (my computer has had the hard drive replaced & I lost all the contacts).
Offline micko
« Reply #7 on: July 01, 2015, 01:46:02 pm »
Sorry, couldn't get out to the shed last nite. I will look tonite, I have a brand new one - just have to check the axle size
Offline micko
« Reply #8 on: July 02, 2015, 04:04:24 pm »
Sorry, its the 17mm. Must be 77 "B"
« Reply #9 on: July 02, 2015, 05:12:05 pm »
I am still interested in a B plate aswell.
« Reply #10 on: July 22, 2015, 08:02:09 pm »
I am still needing a 76 plate.
« Reply #11 on: October 24, 2015, 11:43:05 am »
Still looking for a A model plate.
« Reply #12 on: October 24, 2015, 12:03:42 pm »
New ones come up all the time, even the "mag" one.....try Paul Millar cycles in the US
Offline Oldfart
« Reply #13 on: October 24, 2015, 03:41:39 pm »
Think I have one gathering dust....
« Reply #14 on: October 24, 2015, 06:23:12 pm »
Never seems to be any when i have looked but that has been used one. Maybe i need to search by part number for NOS one then.
Another thing, the 76 parts book shows these parts but i dont understand why it would have these when the brake is non floating. If this is the wrong drawing, does anyone know a site that has the correct one for the 76?
« Last Edit: October 24, 2015, 06:45:10 pm by LWC82PE »
