Author Topic: RM250C and C2 Fork set up  (Read 3219 times)
Offline minifig-phil
« on: June 23, 2015, 02:33:20 am »
I have a RM250C2 that I'm setting up for vintage MX.
I have both C and C2 forks and would prefer to use the C forks since I'm pretty short and would like the bike a little lower.
What are you guys doing with the internal set up for these forks
RaceTech has stiffer springs that don't require air but do you still use all the top out springs?
Offline micko
Re: RM250C and C2 Fork set up
« Reply #1 on: June 25, 2015, 06:53:55 pm »
From my experience (RM125B forks) u don't run the Negative spring if your not going to run air, but u will have to make a spacer to replace it otherwise u gain more than 9" travel.
« Reply #2 on: July 07, 2015, 05:29:19 pm »
What is the length difference between the C and C2 forks?
Offline crs-and-rms
  • heaven 23
« Reply #3 on: July 10, 2015, 08:47:29 pm »
fit emulators
