Author Topic: kdx 200 electrics 1987 model  (Read 7623 times)
Offline BA #63
« on: June 16, 2015, 09:28:18 pm »
hi guys I know this has been asked before but maybe someone  knows a new trick will the complete 89 to 94 electrics ( water cooled ) work on the 86 to 88 ( air cooled ) or should I have a KDX 200  bonfire (I HAVE SEEN PVL FOR ENDURO BIKES  AROUND $300)
CHEERS
I am still the fastest in the pits
Offline Gday
Re: kdx 200 electrics 1987 model
« Reply #1 on: June 17, 2015, 09:05:56 pm »
If you are gaving problems with the original ignition The source  coil is often the fault . Easy fix
http://pages.ebay.com/link/?nav=item.view&alt=web&id=351252329258
Stator Ignition Source Coil Kawasaki KDX 200 1985-1988
Offline BA #63
« Reply #3 on: June 17, 2015, 11:54:12 pm »
thanks guys but its the flywheel magnets that have broken up but 89 up parts are easy to get
« Reply #4 on: June 18, 2015, 12:17:18 am »
I would make the assumption that if you use all the parts from the one model; flywheel, stator & black box then it will all work together okay.
The big question is the stator the same size to be able to bolt into place and does the flywheel have the same taper.
I reckon the flywheel will fit the taper okay but wonder if the depth to the stator will be the same.
Stator size of the 86 200 is bigger than the 175 so a measurement of an post 88 model would be handy.
I'm interested to know how you get on as one day I will need a complete ignition for an 86 200 as well
Offline tymes
« Reply #5 on: June 18, 2015, 02:12:07 am »
My 84 200 currently has a 96 flywheel with the original 83-4-5 stator coils. I cut a new keyway in the tapered hub once I had the timing sorted due to the magnets being a different offset to the earlier model. The angle took a bit of working out. I eventually got it right by useing a timing light to pinpoint new timing marks then engraving the new timing marks on the flywheel and finally measuring the piston height with a dial gauge to time it.
I didnt even bother having a key in the shaft for about twelve months and never had a problem with it moving on the shaft.
The magnets dont come loose and destroy the coils on the later model flywheel, something that is a real problem on the earlier model flywheels as they get old.
I dont know about the 86-8 model ignition if the same can be acheived with its original coils, but I would asume that changing the entire ignition to a later model might give rise to some problems with advance curves and characteristics of the CDI unit that may not bid well with the earlier air cooled donk.
If I had the parts id try it just to see what happens.
Brian
Offline Paulos
« Reply #6 on: June 18, 2015, 08:10:49 am »
There's a shit-stir in the making
« Reply #7 on: June 18, 2015, 10:14:14 am »
He did say "one day". There was no suggestion of which week/month/year/decade or even century that day would be.
:D
« Reply #8 on: June 18, 2015, 03:02:40 pm »
Muuum, the guys are picking on me again
Young Nathan I will have you know that all my Kawasaki's were only picked up this century, it's only my Maico resto and my CZ & HL builds that have been dragging on since the last Millenium
Offline BA #63
« Reply #9 on: June 18, 2015, 11:33:02 pm »
thanks for the input I will try the 1990 electrics and will let you know the out come
cheers :)
