Author Topic: Wanted Piston Pin Washers  (Read 3179 times)
Offline Tossa
« on: June 08, 2015, 12:19:49 pm »
Wanted Piston Pin washers for 1974 CR250
Barry
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
Offline Brian Watson
  • First Penton in OZ
Re: Wanted Piston Pin Washers
« Reply #1 on: June 08, 2015, 05:58:42 pm »
Barry, as mentioned on the phone, we are not using the spacers when using a Woosner or Wiseco piston... anyone else using them??..we aren't..
Offline Tossa
« Reply #2 on: June 08, 2015, 06:21:25 pm »
they were in the MAG when Paul took it apart and he placed them in the 79  so that one is ready to go and now would like to place some back in the MAG
Offline grouty
« Reply #3 on: June 08, 2015, 06:31:33 pm »
If you are using Wossner pistons, you won't need the silly little alloy spacers. They have a narrower gap for the little end.
My 390's run 18mm dia small end pin. I use a genuine Kawasaki small end bearing. This fits perfectly between the bosses in the piston.
Thumpers Rule !
