Author Topic: Kawasaki KX125 KE125 help please  (Read 9721 times)
« on: June 03, 2015, 06:59:43 pm »
Hi blokes, I am building/collecting parts for a 1974 KS/KE125 VMX build.
Finally scored a close ratio tranny cluster last night 8) 8) 8) 8)
The seller also has this bit of a KX125 for sale
My question is;
Does the 1974 KX125 run a bigger carby than the KE125?
If so I should grab it too?
Thanks if anyone knows :)
Offline teabag1
Re: Kawasaki KX125 KE125 help please
« Reply #1 on: June 03, 2015, 09:01:19 pm »
74 KX125 has a mikuni VM26SC and the 74 KS125 has a Mikuni VM24SC. If you can get another carb at the right price I would grab it. I also have the standard jetting specs if you need them.
« Reply #2 on: June 03, 2015, 10:04:36 pm »
Thank you mate, I appreciated the knowledge ;)
He only wanted AU$9.68 and it wont add much weight to the parcel.
Bargain.
« Reply #3 on: June 04, 2015, 12:08:21 pm »
« Reply #4 on: June 04, 2015, 08:41:31 pm »
This is the carby you really want
http://2stroker.createforumhosting.com/post65807.html
Thanks Lozza, that is most definitely the eventual path I will tread, after my VMX build dreams budget recovers ::)
In the meantime with teabag1's help I have identified the original 74 KX125 carby as a Mikuni VM26SC F7-5
the identical carby fitted to the KE175(except for jetting)
Goldsby has kindly given me one of them and teabag1 has offered jetting specs to get it up and running 8)
Thanks fellas.
In the meantime Lozza could you give me a ball park for preferred opening and closing of the rotary valve for motocross? please
« Last Edit: June 04, 2015, 09:52:02 pm by Mick D »
« Reply #5 on: June 05, 2015, 09:47:24 am »
depends what the standard timing is and the rest of the engine but 120/65-70 will be a good start. Top end won't be spectacular but will have great bottom end/mid range. What ever you do, don't ever use a KE/KH piston in a tuned engine or this will happen, about 15 hours work destroyed as soon as the ignition was dialed in
Offline fred99999au
« Reply #6 on: June 05, 2015, 05:38:47 pm »
Just like me. Piston broke.
(I've been waiting years to use that)
Offline Momus
« Reply #7 on: June 05, 2015, 05:46:14 pm »
Expecting more than 15 hours wfo running from cast piston on a highly strung 125 seems pretty optimistic?
Perhaps 5 hours between pistons on an air cooled  MX bike would be safer?
If you love it, lube it.
« Reply #8 on: June 05, 2015, 07:59:45 pm »
Was MY 15 hours work in the cylinder not the piston. Piston lasted 3 blips on the throttle
« Last Edit: June 05, 2015, 08:02:32 pm by Lozza »
« Reply #9 on: June 05, 2015, 08:03:17 pm »
Boom tish  :D
Offline Momus
« Reply #10 on: June 05, 2015, 08:59:22 pm »
Bugger. Commercial job no doubt. Who ate it? You or the customer?
« Reply #11 on: June 08, 2015, 07:09:26 pm »
worse it was a love job AND I said find  better piston
