Author Topic: Honda CR 125M1 1975 cylinder wanted  (Read 3222 times)
Offline Richo52
« on: May 26, 2015, 10:49:44 pm »
Hi guys I need a 1975 Cr125M1 cylinder to complete  my little Elsinore .Please message or ring me on 0437801714 thanks Richard.
SOME BIKES AND CARS
mrsupersport
Re: Honda CR 125M1 1975 cylinder wanted
« Reply #1 on: June 04, 2015, 12:56:01 am »
How about a 175 topend? Make a cheater :)
Offline Richo52
« Reply #2 on: June 04, 2015, 02:12:41 am »
Does it have a piston and cost thanks .
SOME BIKES AND CARS
« Reply #3 on: June 04, 2015, 07:28:30 am »
175 top end is not an easy fit (LOTS of work to do), with the end result a much slower CR175 than a stock CR125. Been there, done that but if you really want to, I have cases & top end here for MR175.
Offline Richo52
« Reply #4 on: June 04, 2015, 08:39:55 am »
Thanks for the info BigK ,why is the larger motor slower ?
SOME BIKES AND CARS
« Reply #5 on: June 04, 2015, 10:24:53 am »
Doesn't rev as quick, MR porting way different, pipes wrong, the list goes on. You can make a nice mid size enduro bike, but a standard CR125 is a better MX bike. Done RM & KX as well, same result.
Offline Momus
« Reply #6 on: June 04, 2015, 03:48:08 pm »
Those cylinders are a bit hard to come up with here; US Ebay is a better bet.
 The Yanks are much more ready to part out bikes.
 There are usually a couple with bores left floating around there . I picked up one with damaged fins for $25 bucks the other night.
I went through the MR175 CR125 thing for MX  last year.
As Big K says it is not easy. I eventually thought to buy a complete MR engine and swap the CR ignition and gearbox into the quite different cases and port the cylinder and make a pipe.
 In the end I canned the idea as having already reached the point of diminishing returns.
If you love it, lube it.
Offline Richo52
« Reply #7 on: June 04, 2015, 08:04:17 pm »
Thanks for the replies BigK and Momus,Im onto a cylinder at the moment will stick to a 125cc barrel.
SOME BIKES AND CARS
