Author Topic: MOTOPLAT QUESTION  (Read 8454 times)
Offline gra1961
MOTOPLAT QUESTION
« on: May 13, 2015, 07:58:31 am »
SHOULD THE MOTOPLAT FROM A 86 500MX WORK ON A 86 250 MX? FROM WHAT I CAN SEE THE ONLY EXTERIOR DIFFERENCE IS THAT THE WIRING COMES OUT OF THE STATOR IN A DIFFERENT SPOT.
Re: MOTOPLAT QUESTION
« Reply #1 on: May 14, 2015, 08:56:48 am »
Why not try?
You can fit PVL on 250's
Offline gra1961
« Reply #2 on: May 14, 2015, 05:05:01 pm »
I BOUGHT THE IGN ON EBAY FROM SOME FROG AND HE SAID IT WAS FROM A RUNNING BIKE AND FROM A 250 BUT IT HAS THE WIRING COMING OUT FROM THE SAME SPOT AS MY 500 IGN.I FITTED IT TO  A 300 IAM DOING AT THE MOMENT ,SPARK BIG AND FAT BUT BIKE WONT FIRE I THOUGHT MAYBE IGN WAS WRONG BUT I WILL LOOK FURTHER AND DRINK MORE BEERS AT IT AND SEE WHAT HAPPENS.
« Reply #3 on: May 14, 2015, 06:06:18 pm »
dont use caps its rude
anyway if you have a good spark fuel and compression its not firing in the right place.did you check if the firing point is correct for the bike its fitted on.you might have to not use the keyway and just lock it on the tapper were it should be before top dead center.have fun
jim
Offline Blackjack
« Reply #4 on: May 15, 2015, 11:57:15 am »
The Motoplat uses more advance than the later SEM ignitions.
Offline supermotomc
  • SWM ktm, dealer mechanic 1977-1995
« Reply #5 on: May 15, 2015, 05:26:58 pm »
Start by assemble as is in the same pos as original get you two mm drill align through flywheel to stator that will give you a static firing point! this is where you need that dial gauge that you were always going to bye! now from static point remove pin advance to TDC  theres your currant timing  if its not as should be then this is where the grey matter comes to the for by repositioning the base plate Enjoy OH timing 2.2 mm to 2.4 for more down the bottom
« Last Edit: May 15, 2015, 05:39:38 pm by supermotomc »
Offline jurado
« Reply #6 on: May 29, 2015, 04:31:54 pm »
I have one 90´ktm 500 with SEM and another one with Motoplat. Motoplat always worked better for me. Bike always fires at first kick, even when cold. It is easier to fire the bike with Motoplat than with SEM, as the rpm spark threshold is lower (around 300 rpm) for Motoplat.
What Motoplat do tou have?, Look at the number on the flywheel. The standard MX ignition Motoplat is 9600 176-1. It has no light, only two wires. Spark threshold is around 300rpm. Used on: 390-495 1979-84 , 350-550 water cooled, 250 79-85 (86). Also used on 83-85 250 mx
Timing should be 2.1 – 2.2 mm BTDC. You will need a micrometer to properly set it.
Other Motoplats are:
MXC Ignition: 0616026
With light, three wires 6V 35W, for head light only.
This one was available for the big bores from 1982 and up, Spark threshold around 400rpm.
This was also the recomended ignition for the 500/85-86 for the ones who needed a head light. Same is true for all other big bores to replace the five wire 9600 162-1 With the five wire 9600 162-1 it was too difficult to start the 500...
It was used for: 420-495 82-84, 350-550 water cooled, 250 82-83 (can be used up to 86)
Standard Enduro Ignition: 9600 162-1
With light, five wires 6V 35/5/21Watt. Spark threshold around 650rpm.
Some people say this one was the bad one. Bike does not rev with this one. Probably due to a bad ignition curve?
This one was used on ALL KTM up to 1981.
125-400 75-78, 125 79-80, 250 79-86, 390-495 79-84, all water cooled 350-550
Only 125/81 got a new one, see below.
Enduro Ignition, New for KTM 125 1981 and up: 0616016
Seems they have changed the ignition curve here for the high rpm of the 125!
Some people say it helps the big bore too, but I doubt it. If it would, then KTM would have dropped the 9600 162-1, but they used it for the big bores until Motoplat died....
Used on the 125 only from 81-83, but will fit and run on big bores too!
New ignition for KTM 125-84: 0616028
With light, five wires 6V 3575/21Watt.
In 1984 they changed the ignition of the 125 again to 0616028. This ignition will not fit any other KTM! (I'm not sure about this, but I think at least they used a smaller mounting plate for this ignition.)
This one should fit all 125cc at least up to 1997...
Good luck.
Offline gra1961
« Reply #7 on: June 09, 2015, 06:25:10 am »
all fixed.i thought that all the flywheels were  the same.changed flywheel to suit the stator i had fitted,reset timing,1st kick
