Author Topic: Ducati 477 motocrosser build .  (Read 98189 times)
Offline Eldert
« on: May 11, 2015, 06:19:58 am »
Hi guys
i am in the process off building a Ducati single motocrosser from scratch .
i made a facebook page about the build . the page is called :
the build of a 450/500 Ducati motocrosser
if anyone is interested send me message thru facebook so i can add you
Regards Eldert Rademaker
« Last Edit: July 29, 2015, 08:54:05 pm by Eldert »
Re: Ducati 477 motocrosser build .
« Reply #1 on: May 11, 2015, 12:53:49 pm »
Nive what frame are you using? Firko has one in a hindle frame.
Offline Eldert
« Reply #2 on: May 11, 2015, 03:10:18 pm »
frame is a homebuild job by a friend . it is styled a little after a Cheney BSA
Eldert
Offline popeye
  • 1-2-3 wheel's l don't care...All good fun.
« Reply #3 on: May 12, 2015, 06:59:07 pm »
That looks really cool, good luck with the build,
IN IT FOR THE FUN OF IT. LIKE MR NIKE SAYS JUST DO IT.
Offline Eldert
« Reply #4 on: July 29, 2015, 09:02:05 pm »
progress is slow :
Eldert
Offline jimson
  • Sanctuary point N.S.W
« Reply #5 on: July 29, 2015, 10:33:20 pm »
Starting to come together & looking very good. Jimson
Offline Eldert
« Reply #6 on: January 31, 2016, 10:59:04 pm »
had a high level exhaust system made for the bike. fitted a chain guide . put new knobby's on
next is the engine build .
Eldert
Offline k2000x
« Reply #7 on: April 03, 2016, 08:18:06 pm »
Don't go over the top with bumping up the compression you will pull the cylinder studs right out of the cases there shit material
Offline Eldert
« Reply #8 on: April 05, 2016, 12:52:20 am »
i would not worry about that . i put 24.5 mm long timeserts in the cases .
never had a problem in 25 years roadracing Ducati singles .
Eldert
« Reply #9 on: April 05, 2016, 12:15:19 pm »
Great bit of kit Eldert, dont mean to pick, just saying, would luv to see old school mega phone on it, bloody good choice muffler you got there for racing  ;)
Offline popeye
« Reply #10 on: April 15, 2016, 07:15:07 pm »
I'm with you Pete old mega phone would be my choice just MO...
Coming along nice thou looks fantastic.
Offline EdgyAl
« Reply #11 on: April 16, 2016, 09:16:41 am »
Nice work,
What are the other specs, wheels, brakes, forks etc?
It's coming together very nice.
Offline Eldert
« Reply #12 on: April 17, 2016, 07:15:27 pm »
front wheel is from a Moto Morini Kanguro . for the rear i wanted something with a rubber mounted sprocket carrier to make things easy on the gearbox . found out a Yamaha XT 350 has a transmission damper in the hub and its pretty light .
front forks i made myself . sliders are Betor from a Cagiva . stancions are from a Honda VTR 250 and have sliding bushings . i had the cagiva sliders honed 1mm bigger for the bushings .
made damperrods out of 6061 aluminum and had them hard anodized .
put racetech emulators on top of the rods .
tripple clamps are Marzocchi .
Eldert
« Last Edit: April 17, 2016, 07:35:19 pm by Eldert »
Offline Eldert
« Reply #13 on: April 27, 2016, 06:15:53 pm »
My Belgium friend Herman's  pre 65 Ducati's  . engines are 1963 four speed 250's taken out to 370cc
Offline Eldert
« Reply #14 on: June 15, 2017, 01:41:53 am »
it has been a while but a little update on the bike .
engine build is done . i put a HPI ignition on it and it is a first or 2nd kick starter . very nice idle and it pulls like a freight train from low down . i did not put this engine on the dyno but it should have 38 / 40 rw hp
Eldert
« Last Edit: June 15, 2017, 02:02:10 am by Eldert »
