Author Topic: YZ465 engine weight  (Read 3402 times)
Offline bishboy
  • Toowoomba
YZ465 engine weight
« on: April 29, 2015, 04:51:58 pm »
Does anyone know what a YZ465 engine weighs??
Trying to sought out some freight prices and they don't have a set of scales where the engine is  ::)
Re: YZ465 engine weight
« Reply #1 on: April 30, 2015, 08:11:31 am »
Somewhere in the 20-30kg range would be a safe bet - and most couriers won't check whether it's 25kg or 30kg ;).
I've posted a couple of 125 motors and they usually come in around 20kg inc packaging.
You can send a bigger motor through Auspost in two packages to get below the 23kg limit - bottom end in one, top end in the other. Don't know if this is still economically sensible since Auspost jacked their priced up.
Offline KTM47
« Reply #2 on: April 30, 2015, 10:23:07 am »
Stand on some bathroom scales take note of the weight.  Then stand on them holding the motor.  Then simple maths.
MAICOS RULE DESPITE THE FOOLS
Offline bishboy
  • Toowoomba
« Reply #3 on: April 30, 2015, 11:07:41 am »
They don't have any scales where the engine is...
Thanks for the info Nathan, figured probably around that 25-30kg
