Author Topic: Mikuni 38 mm round slide  (Read 7774 times)
Offline Slow Pete
« on: April 11, 2015, 01:01:16 pm »
Hi All,
         I have just put a new needle jet in my carb and it is not as long as the original, the main jet still goes in and is in the right place but there is no room for the round thing called the cup that fits above the main.   Anyone come across this before ?   Looks like it should still run without it but I assume its there for a reason.
Past owner of.  Bultaco 125,  Suzuki RM250A, RM125C, RM125T, RM400N, RM125X, Maico AW250 1977.   Presently 81 RM250X , 87 RM125H , 86 RM250G & 81 RM125X.   Current projects 80 RM400T & 78 RM125C
Re: Mikuni 38 mm round slide
« Reply #1 on: April 11, 2015, 02:09:48 pm »
Sounds like you have the wrong series needle jet fitted. The cup you refer to acts as a baffle to minimize fuel surging from what I can see & if possible I'd use it as per how it left the factory
Offline bazza
« Reply #2 on: April 11, 2015, 05:36:48 pm »
How much shorter is it? If it is not as the one that came out why use that type?
Embrace patina
Offline mick25
  • Hunter valley NSW
« Reply #3 on: April 11, 2015, 06:02:29 pm »
Unless the one you took out was the wrong one ? And the new one is right .
I have found this out with these old rockets we play with , some bikes have had so many owners over the years and funny things happen when the wrong parts are fitted and the new owner thinks that part is the right one .
Offline Slow Pete
« Reply #4 on: April 11, 2015, 06:30:39 pm »
Could be Mick,   Its starts ok and revs out much better with the new one.   [It was running rich]   I will take it for a ride tomorrow and see how it goes.  If it doesn't work I will put the old one back in.
« Reply #5 on: April 11, 2015, 06:46:15 pm »
That needle jet you fitted is a different series for a different carb, you need the correct one and use the main jet baffle.. The series is stamped on the side of the needle jet
Offline ARN
« Reply #6 on: April 11, 2015, 07:43:20 pm »
mikuni make a main jet extender piece that screws into needle jet before main jet  there on ebay
Offline bazza
« Reply #7 on: April 12, 2015, 03:35:21 pm »
If have to use old needle jet (runs rich) try needle with same angles and length but fatter (to lean) ??
Embrace patina
