Author Topic: Fork oil RM125B  (Read 6247 times)
Offline YZAT252
Fork oil RM125B
« on: April 10, 2015, 12:18:22 pm »
Hi Guys, can someone tell me the right quantity and best grade / type of fork oil to put in my RM125B? Also, how much air pressure?
Re: Fork oil RM125B
« Reply #1 on: April 10, 2015, 12:38:50 pm »
Offline YZAT252
Re: Fork oil RM125B
« Reply #2 on: April 10, 2015, 01:33:38 pm »
That is awesome, thank you for that, will come in real handy.
Re: Fork oil RM125B
« Reply #3 on: April 10, 2015, 02:20:18 pm »
Offline Daryl Jones
    • Old Bike World
Re: Fork oil RM125B
« Reply #4 on: April 11, 2015, 09:35:16 am »
A Ton (or two) of really good information, Thank-you.
cheers, DJ
Charles Kettering.
Offline YZAT252
Re: Fork oil RM125B, what weight?
« Reply #5 on: April 16, 2015, 09:56:27 am »
What weight fork oil do you recommend? Original manual says 20W, with 20psi of air, thinking maybe 15W Motorex??
« Reply #6 on: April 16, 2015, 06:47:51 pm »
Why do you think lighter would be good? Are the forks stock internaly?
I have an old Shell oil manual and it lists 20 fork oil as 59 CST at 40 degrees closest non fork oil to that is Tellus 68 which is a hydralic oil. I have used it and the 32 version of it in the past and it works well.
The original oil and pressure specs assumed a rider of around 60kg and if you are like the rest of us I'd start with a little more pressure and oil weight and give it a go.
