Clubroom
Tech Talk
Keihin slide cut away
Topic: Keihin slide cut away (Read 1865 times)
evo550
April 07, 2015, 09:48:25 pm »
Is it possible to change the cutaway on a slide, wanting to change from a 3 to a 3.5, but the dealer wants $165 for a slide?
, so I figure may be able to mod existing slide.
Thoughts?
oldyzman
250 two stroke!
Re: Keihin slide cut away
April 07, 2015, 09:52:14 pm »
Yep, you can file it, by using a file wrapped in wet and dry say 180 or 240, be strict on the strokes and mark with a texta before you start. If you r real keen attack it with a linisher using an old belt.
evo550
April 08, 2015, 09:48:30 am »
Thanks,
Do you know if the profiles are avaliable on the WWW ?
Clubroom
Tech Talk
