Marque Remarks
Maico
1965 Maico Oval Barrel 360
Topic: 1965 Maico Oval Barrel 360 (Read 8517 times)
DCPlasticsguy
C-Grade
April 07, 2015, 07:56:02 am »
Don is working on a 1965 Maico Oval Barrel 360. He needs a new rod pin and rod bearing. Would also consider a decent crankshaft. Any leads on one? I have not found any sources in Europe or the USA so far.
sleepy
Re: 1965 Maico Oval Barrel 360
April 07, 2015, 11:09:25 am »
Have you got any dimensions, it may be possible to use something later with some mods. Even custom made pin is possible.
DCPlasticsguy
C-Grade
April 07, 2015, 09:32:40 pm »
It's actually at Mr Crankshaft right now. He has not been able to match it up with anything else that he uses, and he goes through the full catalog of PWC, ATV, snowmobile, etc rods and pins.
sleepy
April 08, 2015, 10:06:01 am »
Sorry don't know Mr Crankshaft, where in Oz are you?
Hoony
Melbourne, Vic.
Reply #4 on:
April 08, 2015, 07:45:06 pm »
i think DCplastics is in Yakee Doodle Land
Long time Honda Fan, but all bike nut in general, Big Bore 2 stroke fan.
http://www.youtube.com/watch?v=XJoKP6MawYI
sleepy
Reply #5 on:
April 08, 2015, 08:49:14 pm »
I guess it wouldn't be any use offering to take a look at it then.
paul
Reply #6 on:
April 09, 2015, 08:28:40 am »
don give paul stacker a ring idont think this would be a problem for him as long as you don't mind sending the crank/rod /piston to Australia
split crank resize rod new bearing maybe make a pin ect,there been doing that stuff for years
ring paul
btw he.s probably a customer of yours as well
6 Beatrice Avenue, Heidelberg West VIC 3081
(03) 9459 9535
Last Edit: April 09, 2015, 08:30:38 am by paul
Superstar
Reply #7 on:
May 01, 2015, 12:09:29 pm »
Use a square barrel crank Don. I am using a 74mm stroke 350 squarie crank in my own 360 oval barrel project.
Marque Remarks
Maico
