Author Topic: YZ 250H Ignition Advance Curves  (Read 33485 times)
Offline peter l
Re: YZ 250H Ignition Advance Curves
« Reply #30 on: April 20, 2015, 08:00:43 pm »
I have run one of these hpi ignitions on my yz250g for about 3years ciscos originaly did mine I think they did the timing curves as well
it did pick up a couple horsepower over stock ignition  on dyno but in real world conditions the bigger horsepower curve isn't that easy to ride on tight motorcross track so I run the other curve that's in my box I don't know if they used the curves posted they told me they did there own I am going to buy the program to play around with timing curve because I think there is more to play with to smooth out power delivery but overall the actual unit has been reliable
peter
« Reply #31 on: April 21, 2015, 09:41:58 am »
OK.  Here's the HPI curve for the ignition for the model they suggest.
Just looking to compare with the original.  I found one for a 465 but obviously quite different.
Get them to supply a few extra pistons for the holes you will put in them with that curve. Especialy on that curve 2. Looks like a amature guess/stab in the dark. Will run good down low then come to an abrupt brickwall around 7000 then hole a piston if you keep reving it
Gee ever helpfull again.
I realy get a good laugh form your posts. Makes you wonder how 2 strokes ever ran with a pionts system without curves.
sigh rolleyes facepalm
Offline YZ250H
  • Back in QLD Baby !
« Reply #32 on: April 22, 2015, 07:21:08 am »
Thanks for the feedback Peter.
I'll keep researching and put what I find up on here.
