Clubroom
Bike Talk
what bike has 30mm forks with leading axle
All
Topic: what bike has 30mm forks with leading axle (Read 13392 times)
jimg1au
March 19, 2015, 08:31:57 pm »
need a set of forks to replace my gtmx80 forks on my slider project
the trail is all out of wack need to use the tripples on the bike and get a set of forks
thanks
jim
pokey
Re: what bike has 30mm forks with leading axle
March 19, 2015, 08:56:54 pm »
Heaps
check out my favourite fork size website. very handy.
http://organ-donor.org/motorcycle-data/fork-tube-diameter-list/#tube32
Daryl Jones
B-Grade
March 19, 2015, 09:00:57 pm »
Particularly, this one with the 30mm forks.
http://organ-donor.org/motorcycle-data/fork-tube-diameter-list/#tube30
OOPS! Apologies to pokey
. That came across as rather "Dickish"
I was posting at the same time and had saved the link to the 30mm page,
but it just takes you back to the main list.
Cheers DJ
Last Edit: March 20, 2015, 05:32:19 pm by Daryl Jones
Charles Kettering.
jimg1au
March 19, 2015, 09:08:22 pm »
thanks now to see which one has leading axle
jim
jimg1au
March 19, 2015, 09:20:46 pm »
in keeping with the pre1978 concept i will have to get suzuki rm100A OR B forks
LWC82PE
Superstar
March 19, 2015, 09:51:55 pm »
Are 76/77 100 forks leading axle?
jimg1au
March 19, 2015, 09:56:07 pm »
yes i belive so as per google rm are and tm are not
looked again and there was 3 different bikes in all
parts show the c has leading axle is that a pre78 bike
jim
Last Edit: March 19, 2015, 10:04:02 pm by jimg1au
motomaniac
Reply #7 on:
March 19, 2015, 10:04:24 pm »
Quote from: jimg1au on March 19, 2015, 09:56:07 pm
RM125 a FORKS ARE NOT LEADING AXLE , DOUBT IF THE 100'S WOULD BE
LWC82PE
Superstar
Reply #8 on:
March 19, 2015, 10:10:14 pm »
That's what i was thinking too.
C is a 78 model so not pre 78 legal
thought i would check
http://www.alpha-sports.com/suzuki_parts.htm?fpg=/smoto/1976%20RM100/13.htm
http://www.alpha-sports.com/suzuki_parts.htm?fpg=/smoto/1977%20RM100/13.htm
Last Edit: March 19, 2015, 10:12:48 pm by LWC82PE
jimg1au
Reply #9 on:
March 19, 2015, 10:15:54 pm »
might have to use 27mm yamaha yz80 1977
there is 27mm forks on the bike with sleves to take up the difference
didnt realy want to do that but might have to it works well enough
jim
ola_martin
Reply #10 on:
March 19, 2015, 11:37:00 pm »
Both Marzocchi and Ceriani have 30mm 50cc mx forks, not sure about leading axle though.
vandy010
#789 MX125a BMCC Brisbane
Reply #11 on:
March 20, 2015, 11:01:22 am »
Later model AG175 forks are 30mm leading axle too...
"flat bickie"
jimson
Sanctuary point N.S.W
Reply #12 on:
March 20, 2015, 04:26:57 pm »
My son has a GT80 with postie forks they fit right in the triple tree. Just change the bottoms over to leading axel ones. Jimson
Daryl Jones
B-Grade
Reply #13 on:
March 20, 2015, 05:48:52 pm »
Get the hone out.
Honda has 31mm leading axle forks from CR125 (rarer) to 76-77 XL125 (plentiful).
DJ
Charles Kettering.
Tim754
Northern Country Victoria
Reply #14 on:
March 20, 2015, 08:02:05 pm »
Add the early CT125 Honda Agi to Daryl’s list off 31mm leaders
and of course the later ones plus CT200 auto agi as they well never changed.....
Last Edit: March 21, 2015, 07:42:42 pm by Tim754
All
Clubroom
Bike Talk
