Author Topic: 81pe175 complience plate wanted or one i can use.  (Read 8890 times)
Offline suzuki447
« on: March 04, 2015, 09:57:35 pm »
after a compliance plate to get my pe rego,d .
bikes in shed.74tm125,76,78,82rm125s,...82,83rm250s.80canam qualifier.80,83yz125s.86yz490.80it125.76it400.80pe175and250.79rm50.76xr75.2xpuch50 magnums.jawa speedway.72honcho 90.84xr200.87xr100.phew thats all.
Offline Goose 29
Re: 81pe175 complience plate wanted or one i can use.
« Reply #1 on: March 18, 2015, 09:37:44 am »
I have a couple but are 1979 and 1980 I think,
I am in Melbourne. Andrew.
Offline suzuki447
« Reply #2 on: March 18, 2015, 09:13:31 pm »
interested in 80plate. my ph 0410383202 tx me how much .thanks don.
« Reply #3 on: March 18, 2015, 09:39:34 pm »
Keep in mind that the compliance plate number is supposed to match the number stamped on the frame too on Suzukis.
Offline Goose 29
« Reply #4 on: March 19, 2015, 10:14:13 am »
My plates are next to stamped frame and do not match on both bikes.
« Reply #5 on: March 19, 2015, 10:45:14 am »
what reg and what state are you in?
Offline kdx Geoff
« Reply #6 on: March 19, 2015, 11:46:17 am »
So does that mean that the frame number on the frame isn't identical to the frame number on the compliance plate ?
« Reply #7 on: March 19, 2015, 05:34:26 pm »
I got 6 suzukis and all the compliance plates have the number matching the frame number
I would say either someone broke a frame and replaced it or 'lost' the comp plate and stuck another one on it.
Offline DR500
« Reply #8 on: March 19, 2015, 11:14:41 pm »
when you get a rwc inspection they will check that they match up
Offline b490
« Reply #9 on: March 20, 2015, 09:13:46 pm »
 Compliance plate  requirement  for registered  motorcycles sold  in Australia  was  introduced for motorcycles produced  on or after
                                                    the  1st October 1976 .
   Frame  #  /  ID #   stated on compliance  plate  must   match  frame / ID number  of the bike.
  Regards ,
                         Steve
« Last Edit: March 20, 2015, 09:18:39 pm by b490 »
« Reply #10 on: March 21, 2015, 08:56:40 am »
if your in Victoria and chasing club reg or recreational reg you do not need a compliance plate
Offline frostype400
« Reply #11 on: March 21, 2015, 10:20:34 am »
The engine number won't match on a pe but the frame neck number and Comp plate always do you won't need the plate for rego installing one not from the bike will come across as dodgy illegal to do.
They don't look at the comp plate if you are worried take some photos of where it normally is they will see the rivets every time I have taken Vic roads a car or bike they only wanted to see the vin and engine number.
1971 tm400 and PE's
Offline oldyzman
  • 250 two stroke!
« Reply #12 on: March 21, 2015, 01:46:07 pm »
so can i get a TM250 1974 registered in NSW, if it has the correct lights etc?
« Reply #13 on: March 21, 2015, 04:08:32 pm »
Every time I have taken bikes to Vic Roads, new or old, to be registered or re-registered, they ALWAYS check the compliance plate for the date. They rarely check that the frame number matches though. I have done this hundreds of times.
« Reply #14 on: March 21, 2015, 04:18:16 pm »
You won't need a compliance plate prior to 76 as they didn't exist earlier.
However it will have to meet all of the rego requirements
Getting a bike registered without one should be easier if you have proof it had previously been registered.
« Last Edit: March 21, 2015, 04:55:55 pm by GMC »
