Clubroom
Tech Talk
RM 125A
Topic: RM 125A (Read 3049 times)
bigtoe
C-Grade
RM 125A
March 03, 2015, 06:47:55 pm »
Hi, my sons rm125a needs rebuilding, could anyone tell us the best place to get crank bearing and seal kits, con rod bearings, probably piston and rings, we are on the gold coast, thanks
Ted
Re: RM 125A
March 03, 2015, 06:49:56 pm »
Speak to Davey Crocket on here. He has one and will no doubt either have the bits or know where you should get them from
81 YZ 465 H 77 RM 125 B
bigtoe
C-Grade
Re: RM 125A
March 03, 2015, 07:27:13 pm »
Thanks ted, ok davey crocket guru of all things rm125 where are you?
JohnnyO
Qld
Re: RM 125A
March 03, 2015, 10:33:00 pm »
Serco in Brisbane sell all those items and also rebuild cranks and do re bores if needed
sleepy
Re: RM 125A
Reply #4 on:
March 03, 2015, 11:37:44 pm »
Just had a flick through Serco's and some other listings and there isn't much available aftermarket for your A model. There are other model RM bit that can be made to fit, PM me if you want any further help.
bigk
Kangaroo Flat Victoria
Re: RM 125A
Reply #5 on:
March 04, 2015, 07:18:09 am »
TS 125 piston is the common replacement, but you can use an Elsinore piston which has a higher dome for more compression if you want to, but will need to use a different rod to accommodate the small end size. It's a bit of mucking around & you'll have to use high quality fuel if you go down that path. I have a genuine NOS RM125A rod kit if you're interested.
Last Edit: March 04, 2015, 07:21:32 am by bigk
Clubroom
Tech Talk
RM 125A
