Author Topic: YZ 490 parts  (Read 2122 times)
Offline SimonC
YZ 490 parts
« on: February 23, 2015, 11:49:38 pm »
Wanted, for an 86 490, rear shock, pipe and muffler,  inlet manifold, reed cage and carby, front brake caliper, master cylinder and hose.
Don't have many parts to swap, a rear hub and brake plate that seems to be roughly of that era, a twin leading shoe front brake plate (I think a slightly later one - there was a thread on here a while back showing the difference between the first ones and the later ones).
Simon
Re: YZ 490 parts
« Reply #1 on: February 24, 2015, 06:35:25 am »
I have a pipe and muffler for the side exh 490
Offline kim80y
Re: YZ 490 parts
« Reply #2 on: February 24, 2015, 10:42:48 pm »
Do you want it to be original?
Manifold from WR500 will allow you to fit a 38mm carb instead of 40mm which is NLA new.
Orig pipes are hard to get, PC pipe is prob best of aftermarket.
Hope that helps a little.
Kim :)
