Author Topic: WTB- 18" 36 hole, alloy rim, Honda spoke 167mm & 36 x 4mm alloy nipples.  (Read 1613 times)
Chasing an alloy rim, silver, 36 hole in either 2.15 or 2.50 width.
Chasing a set of 36, 4mm alloy spoke nipples.
Chasing one RH spoke to suit '86 CR250/500, 4mm, straight-pull, 167mm long.
What may you have?
Re: WTB- 18" 36 hole, alloy rim, Honda spoke 167mm & 36 x 4mm alloy nipples.
« Reply #1 on: February 23, 2015, 05:51:57 pm »
Spoke nipples are here
http://www.smprowheels.co.uk/nipple-sets/alloy-nipple-sets.html
Rim request is a bit too broad. Is it for disc, drum, even/un-even flange size? You can't use any 36 hole rim with any 36 hole hub. Theres different angles and cross patterns
« Reply #2 on: February 23, 2015, 08:13:35 pm »
Thanks to Momus for the stuff.
Offline Paul552
  • HEAVEN #552
« Reply #3 on: February 23, 2015, 08:38:33 pm »
I have stock front and rear off a 84 cr250 re but they were powder coated.
Not sure if you are looking for perfect ones or just rims  ;D
