Author Topic: rear wheel spacers cz250 72 wanted  (Read 7260 times)
Offline k2000x
« on: February 22, 2015, 03:08:26 pm »
Hi sent parts off to get zinced came back minus a chain adjuster and wheel spacers had a spare adjuster but need spacers. Anyone got any
Re: rear wheel spacers cz250 72 wanted
« Reply #1 on: February 22, 2015, 06:02:31 pm »
Do you mean the spacer between the swingarm & hub on the left hand side or the spacer behind the brake plate?
Offline k2000x
« Reply #2 on: February 22, 2015, 09:47:15 pm »
The swingarm to hub spacer think it had 2 on that side
« Reply #3 on: February 23, 2015, 05:18:16 am »
It's a single piece that is stepped, I'll take a photo of the 1 I'm not using not that I have the later swingarm fitted
It looks like CRHighperformance is selling aluminium replicas now
http://crhighperformance.com/?wpshop_product=billet-rear-wheel-spacer-19-95
Offline k2000x
« Reply #4 on: February 24, 2015, 12:27:11 pm »
righto
« Reply #5 on: February 24, 2015, 06:54:14 pm »
What the 73 & earlier spacer looks like
Offline k2000x
« Reply #6 on: February 25, 2015, 09:00:44 pm »
Yeah that's it but there was another spacer  that went on the axle before chain tensioner
« Reply #7 on: February 26, 2015, 05:15:59 am »
Something strange there because mine only ever ran that spacer & the spacer between the hub & brake plate, you don't mean the spacer that also locates the adjuster to the swingarm?
Can you take a photo of the what you have including adjusters & I'll see if there is anything missing
« Last Edit: February 26, 2015, 03:17:31 pm by tony27 »
Offline k2000x
« Reply #8 on: February 27, 2015, 02:35:22 pm »
Yeah that's the one...tony I'm missing the one pictured and the adjuster on
« Reply #9 on: February 27, 2015, 06:29:54 pm »
Think I've probably got a spare set of adjusters, new adjuster set without the nuts for the sprocket side is less than $30nz from CZmxparts
Normally the part on the adjuster is welded in, strange for you to have lost it
Offline k2000x
« Reply #10 on: March 01, 2015, 06:49:20 am »
was the zinc plating guys that lost them..not happy at all
