Author Topic: Disc Brake Front end for 1982 XR250  (Read 10099 times)
Offline Stewart Allen
« on: February 09, 2015, 06:44:27 pm »
Hi,
    Chasing a disc brake front end to fit my 1982 Honda XR250. Expect I will need Wheel, Forks, Triples, Master Cylinder & caliper. Not looking at breaking the bank, just can't see the point in putting work into my current front end.
CHEERS STEWART
Doing it to old things is fun
# 74 Heaven
IT490 Will be going one day soon
CR125M
SL175 bitza
IT250D needs work
CR250RE Not going as yet
YZ125F
Offline BAHNZY
Re: Disc Brake Front end for 1982 XR250
« Reply #1 on: February 09, 2015, 09:24:32 pm »
What size are the fork tubes on this model?
Rod (BAHNZY) Bahn
« Reply #2 on: February 10, 2015, 07:22:52 am »
I'll check tonight, not that large. I was hoping if I got a whole front end it might have larger diameter forks as a bonus.
CHEERS STEWART
# 74 Heaven
CR125M
SL175 bitza
IT250D needs work
YZ125F
Simo63
« Reply #3 on: February 10, 2015, 09:12:44 am »
I run a complete 84 CR250 front end on my XR500 so it's still pre 85 legal.  The single best mod you can do on one of those bikes :)
« Reply #4 on: February 10, 2015, 09:15:19 am »
Hi Simo63, that would be my preference, but as they say beggars can't be choosers.
CHEERS STEWART
# 74 Heaven
CR125M
SL175 bitza
IT250D needs work
YZ125F
« Reply #5 on: February 11, 2015, 08:29:20 am »
Hi Bahnzy, Fork size = 37mm
CHEERS STEWART
# 74 Heaven
CR125M
SL175 bitza
IT250D needs work
YZ125F
« Reply #7 on: February 12, 2015, 09:33:56 pm »
Thanks Noel I'll give him a call tomorrow
CHEERS STEWART
# 74 Heaven
CR125M
SL175 bitza
IT250D needs work
YZ125F
Simo63
« Reply #8 on: February 12, 2015, 09:36:51 pm »
If you're after an XL 250/350 disc brake front end I can help you there. Can also help with an XR600 one as well.
Sunshine Coast
« Reply #9 on: February 12, 2015, 09:40:13 pm »
Hi Simo,
            Would have preferred a 1984 cr250 front end, but I'll see what this guy has got his is only round the corner from work so it might work out ok. Otherwise I'll see what can be done with what you have, transport will require work I'm in Sydney.
CHEERS STEWART
# 74 Heaven
CR125M
SL175 bitza
IT250D needs work
YZ125F
Offline DIRTPILOT72
« Reply #10 on: February 13, 2015, 09:31:43 pm »
easier to find a blown up XR250/350, grab the front end and sell the leftovers. I have done this twice. Get the front end free in most cases.
Honda XR200 x2
Honda XR250
Yamaha Yamahopper QT50
« Reply #11 on: February 14, 2015, 01:45:14 pm »
yep your right  ;)
Disc Brake Front end for 1982 XR250 (now master Cyl)
« Reply #12 on: February 17, 2015, 03:27:44 pm »
Ok, I got an XR 83/84 front end now I just need the master cylinder & lever etc.
Anyone got anything or know what's compatible ?
CHEERS STEWART
# 74 Heaven
CR125M
SL175 bitza
IT250D needs work
YZ125F
Offline Beemeerr11
« Reply #13 on: July 26, 2015, 08:43:14 am »
Hi Stewart,
How did you go with this?
Lou
« Reply #14 on: August 04, 2015, 09:54:12 pm »
Hi Lou,
          Still Chasing master cylinder lever etc.
CHEERS STEWART
# 74 Heaven
CR125M
SL175 bitza
IT250D needs work
YZ125F
