Author Topic: warped clutch plates - how bad is too bad?  (Read 6371 times)
Offline Graeme M
  • Administrator
  • Canberra, Australia
« on: February 08, 2015, 08:25:54 pm »
Just replacing the fibre plates on the IT175 and decided to check the steels. Manual says .002" warp is the limit, and fortunately most are within that. But one is not, it's about .004". You can definitely see it when on a glass sheet. The question is, does that matter so much? I changed the fibres because I was getting a little slip, but maybe it's the warped steel that was doing that? No signs of any blueing or whatever on the steels and everything looks nice and tidy.
My guess is they'll be fine, and maybe put the warped one right at the front of the clutch pack?
Offline Stewart Allen
Re: warped clutch plates - how bad is too bad?
« Reply #1 on: February 08, 2015, 08:31:50 pm »
I've never checked the steels for warpage if the clutch was operation OK. I'd put it in.
CHEERS STEWART
Doing it to old things is fun
# 74 Heaven
IT490 Will be going one day soon
CR125M
SL175 bitza
IT250D needs work
CR250RE Not going as yet
YZ125F
« Reply #2 on: February 08, 2015, 08:48:28 pm »
Warped plates normally cause dragging not slipping
« Reply #3 on: February 08, 2015, 08:56:59 pm »
Agree, whack it on and if the slippage is gone Taa Daa! if not change the "warped" plate.  Clutch plate warp tolerance specs in manuals is one of few things I disregard as a farce designed to sell you unnecessary new items. Do tension down to the advised specs and avoid ragged and shagged out nut lock plates.
Do you need a clutch basket holding tool ? I usually make one out of an old plate with a piece of shaped rod welded on, for the handle, once made lasts forever and looks professional hanging on the wall with the other 38 that don't fit this size clutch , you have made over the years  .... ::)
« Last Edit: February 08, 2015, 08:59:17 pm by Tim754 »
« Reply #4 on: February 08, 2015, 09:17:31 pm »
Exactly!
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #5 on: February 09, 2015, 09:18:37 am »
If the steel hasn't got any bluing on it Graeme, it should be fine. Bluing is a sign of friction heat.
I have another way of making a clutch holding tool. All you need is an old steel and a fibre. Simply place them in the basket, steel first and drill 4 small pilot holes through the fibre and just enough to leave a mark on the steel. Remove and drill through the steel. Next, choose your size rivet and drill to that size. Rivet together and there you have a clutch locking tool.
Offline Graeme M
  • Administrator
« Reply #6 on: February 09, 2015, 09:25:38 am »
Thanks for all the advice - I reckon I'll just run with it and see how it goes. And neat trick Mark, I'll keep that one in mind!
Offline sleepy
« Reply #7 on: February 09, 2015, 10:31:46 am »
If you are going to re-use the steels get them bead blasted before they go back in. After they have been in use for some time they get glazed which gives them less grip and also seems to make the oil stick to surface as well. The glass bead brakes down the glaze and the clutch will work again. Best result I have seen using this method was a GPZ900 that would savagely clunk into gear and creap forward without the brakes on to being so smooth you could hardly tell that it had gone onto gear.
« Reply #8 on: February 09, 2015, 12:36:30 pm »
a quick once over with some 240# paper and a bit of kero will also do a cheap deglazing.
« Reply #9 on: February 10, 2015, 09:18:38 am »
Yes, it does the trick. I actually glass mine though. Tape some 240 wet n dry to a sheet of glass and use figure 8 pattern to clean up the plates. It's a great way to remove any high spots as well.
