Author Topic: 1961 453 type 125  (Read 6534 times)
Offline gra1961
1961 453 type 125
« on: January 28, 2015, 09:54:30 pm »
i have a 1961 453 type 125 road cz complete bike with another in pieces (175cc) it has no spark anyone got any contacts for parts for these things ,i need points and condensor and assorted bits and pieces and wiring diagram.havnt found as much stuff as i thought i would for this HQ of the eastern block.a cheap electronic ign would be the go.
Re: 1961 453 type 125
« Reply #1 on: January 28, 2015, 10:09:41 pm »
Search for jawashop, they are based in the Czech republic & their service is pretty good with reasonable postage costs, picked up a couple of different carb to airbox connecters for 125/175s for about $6u each
There are a couple of other places to look for over there but I'd need to have a look tomorrow arvo before work to find them
Offline gra1961
« Reply #2 on: January 28, 2015, 10:18:17 pm »
you have one? any info would be great.cheers gregg
« Reply #3 on: January 30, 2015, 03:05:25 pm »
I grew up with them, still have the 175 trials bike that I built a frame for in my teens for classic trials.
Depending on what engine parts you need I may be able to help, the engine is the same for the 175s apart from crank, barrel,head & centre cases so you can use the gearbox, clutch etc if needed.
The 125 head can be used on a 175 with no modifications to increase compression, as standard they always had quite a bit more power than BSA bantams
Jawamarkt
http://www.jawamarkt.cz/en/
Points are 2euro, Vape electronic ignition is 162-166euro depending on 6 or 12 volts, looks like they have looms as well
Jawashop
http://www.jawashop.com/
Points $2.69us
My memory is that the charging system esp. regulator isn't great, I know a guy over here who runs the Vape system in his 350 twin & he loves it
Offline Tomas
« Reply #4 on: January 30, 2015, 03:20:20 pm »
some JAWA/CZ parts here http://www.motoren.sk/
Offline Moto
« Reply #5 on: January 30, 2015, 05:19:02 pm »
These guys have a range of CZ spares
http://www.vintagemotorcyclesparesaustralia.com
Offline gra1961
« Reply #6 on: January 31, 2015, 07:30:37 am »
thanks all.cheers gregg
