Author Topic: HUSKY 1974 MAG 250 Engine  (Read 1553 times)
Offline Husky Parts
« on: January 25, 2015, 09:49:38 pm »
I have a 1974 Mag engine for sale engine number 2033-1689 with matched cases no 21/21. The engine has been rebuilt with many new parts. It has a new rod kit, a NOS Mahle piston ( not Wiseco)/ new bearings all around /new main seals/gaskets/ new small right hand side crank end to accept Motoplat/ new clutch and clutch hub/ new gearshift mechanism roller to eliminate false neutrals/new first gear shaft/new 3rd gear(took a very long time to locate) and various other gears that were needed. The gearshaft has a modification to eliminate the big slop they have in the gear lever. The engine comes with a working Motoplat but does need the backing plate to mount it. There is also a spare  NOS 1st gear shaft and 2nd and 5th gears. These gears and shaft also fit the 1974 CR 400 and 450. The head also has a dual plug fitted.
If anyone is  interested send me  an e mail at [email protected] and I will send you images.
Fernando
0416 198 307
