Author Topic: 86 RM250 Exhaust Valve question  (Read 4053 times)
Offline LegOwt
« on: January 18, 2015, 06:15:50 pm »
Should have paid more attention when I disconnected the exhaust valve when I did the top end on this. I have it back together but can anyone tell me whether I have it right.
To me its not right because the spring appears to do nothing ie there no spring effect when the valve turns.
Love to get some advice on this.
Offline smed
Re: 86 RM250 Exhaust Valve question
« Reply #1 on: January 18, 2015, 06:39:50 pm »
Looks right to me,the spring only comes into play if the valve jams or stops short i'm thinking, to prevent damage,kinda like a damping device :)
« Reply #2 on: January 18, 2015, 06:51:45 pm »
I know nothing about suzi pv's, so this is just a shot in the dark,  but if that is a return spring, you could try flipping it over, as the rotation of the valve may be moving with the spring wind, perhaps flipping it will allow it to work against the wind.
« Reply #3 on: January 18, 2015, 07:51:04 pm »
Looks alright standard Suzuki PV arrangement, the spring is the travel limiter. Give it a rev with the cover off
Offline LegOwt
« Reply #4 on: January 18, 2015, 09:50:53 pm »
Thx fellas.
Offline LegOwt
« Reply #5 on: January 19, 2015, 01:58:46 pm »
So finally, this valve only comes into play at high RPM and only when the engine is running ie there is no movement of the valve if you just turn over engine using the kickstarter??
« Reply #6 on: January 19, 2015, 03:22:03 pm »
Affirmative, in the words of the great Elvis Presley in Terra Firma
" you gotta rev that sucker, you gotta rev it over those triples Doug, you gotta rev that sucker"
Thank you, thank you very much.
« Last Edit: January 19, 2015, 03:25:33 pm by evo550 »
