Author Topic: CR250 79 bearing numbers  (Read 4665 times)
Offline Marc.com
« on: January 15, 2015, 07:57:54 pm »
Does anyone have the bearing numbers for 79 CR, fitting aftermarket trees and want to check shaft dimensions.
Re: CR250 79 bearing numbers
« Reply #1 on: January 15, 2015, 08:09:30 pm »
Good luck with that Mark, as far as I know (& I've tried many sources) they are not available. Easiest thing to do is use the later, readily available slightly less tall set & fit a spacer underneath to fill the void.
Offline Momus
« Reply #2 on: January 15, 2015, 09:48:01 pm »
Marc. I don't know how helpful this will be, but I'm playing around with some late 70 early 80 Honda front  end stuff.
If the steering stem is 26 mm on the journals, and the steering head is a nominal 47 mm bore then the bearing being used is likely based on the 32005X standard series tapered roller that all the majors supply. These have a 25 mm bore standard and Honda supplies a special with 26 mm bore. I had some modified by a mate with hard steel turning tips
 If you have access to a lathe and ceramic tipped tooling it is easy to bore the bearing bores out.  For bikes with odd ball gearbox bearing sizes ,often  the OD can be turned down.
After I did mine I found that All Balls has a Honda kit with the bearings and lip seals for about the same dosh as I paid for the bearings and turning.
If you love it, lube it.
Offline Marc.com
« Reply #3 on: January 16, 2015, 05:40:03 am »
That was really helpful, thanks for that, time to get out the verniers
