Author Topic: disc brake front end to suit 1984 ts125x  (Read 6924 times)
« on: January 15, 2015, 03:50:13 pm »
me old mate wants to put a disc brake front end on his recently purchased Suzuki TS125X 1984, please  ;) thank you :)
Re: disc brake front end to suit 1984 ts125x
« Reply #1 on: January 17, 2015, 04:54:27 pm »
they are 35mm dia forks fyi
Offline Ngapuhi
« Reply #2 on: January 18, 2015, 01:44:17 am »
I have a TS250X front end on my XR500 that I will be changing. Don't know if that will fit?
« Reply #3 on: January 18, 2015, 11:34:24 am »
you would think it would, how much we looking at ;) cheers
Offline Ngapuhi
« Reply #4 on: January 18, 2015, 12:01:58 pm »
Forks, front wheel, brake set up. $150. The master needs a rebuild or swap the rest is good.
« Reply #5 on: January 18, 2015, 12:09:31 pm »
sounds good to me  ;) Ill get onto me mate     cheers
Offline Ngapuhi
« Reply #6 on: January 18, 2015, 12:17:46 pm »
Ok. Located Carrum Vic. I won't be home for a few weeks as I'm working in Adelaide at the moment. See what your mate thinks 8).
« Reply #7 on: January 18, 2015, 02:07:53 pm »
gave him a dingle and left a message with his son, hey ya should have bought them with ya we are in SA ;D where ya working?
Offline Ngapuhi
« Reply #8 on: January 18, 2015, 11:24:02 pm »
Working at the Lend Lease site on North Terrace (new medical school site). There's a chance I may be heading back to Melbourne in the coming weeks.
Offline Tex
« Reply #9 on: January 19, 2015, 11:36:40 am »
I reckon the 125 has smaller diameter forks than the 250.
« Reply #10 on: January 19, 2015, 11:46:24 am »
good point Tex, I know the 125x is 35mm so any chance of triple clamps? me mate got back to me and said yes interested, oh by the way Im going to the Oarora site start tomorrow (shutdown) so long hours and only the home computer, all the best. cheers
« Reply #11 on: January 19, 2015, 12:46:26 pm »
85> DR250S is 35mm and disc but they probably could be a little too short?. 85> DR250 enduro model has 36mm and disc but a little harder to find but would be longer. Pretty sure late 80's DR125 is disc and 35mm too. So is DR200. I would probably be looking for a DR200 set if you wanna stay 35mm. Keep in mind its not just a matter of whacking on a different front end. I you care enough about geometery, handling and travel you should measure up some forks first to make sure what you are thinking of fitting will be suitable as front ends can vary a lot in length even if they are same fork size and from a Suzuki.
« Reply #12 on: January 19, 2015, 01:10:31 pm »
Thank you for all that info and you are on the money, Scotty will fit and tune suspension to his needs and I will pass on the information, cheers
« Reply #13 on: January 19, 2015, 04:40:29 pm »
have PM you Scotty's number
Offline Ngapuhi
« Reply #14 on: January 19, 2015, 10:22:08 pm »
No clamps, but these forks fit the stock 82 XR500 triples if that helps. Got the number I'll call him soon.
