Author Topic: ts250 forks  (Read 1442 times)
ts250 forks
« on: January 14, 2015, 08:10:59 pm »
36mm excellent chrome, anodising on the sliders isn't the best but would clean up. I think they're late 70's early 80's vintage.
$80
Offline Ted
Re: ts250 forks
« Reply #1 on: January 14, 2015, 08:29:02 pm »
Late 70's early 80's would make them Evo. Get with the times. 48mm USD fork are all the rage.
81 YZ 465 H   77 RM 125 B
Re: ts250 forks
« Reply #2 on: January 14, 2015, 09:18:31 pm »
For 36mm TS 250 79-82 they would need to be 811-815mm long from axle hole to top of chrome. 78-79 SP370 are very similar, if not the same but I am not sure on the length of those. Also 80-84 DR/SP400/500S are also very similar at first glance but are 836mm long although 82-84 have air caps. I am considering a 811mm TS250 set as I would like some fork legs with good chrome, so I am considering them if they are the 811mm long type.
« Last Edit: January 15, 2015, 07:24:11 pm by LWC82PE »
Re: ts250 forks
« Reply #3 on: January 14, 2015, 10:05:44 pm »
For 36mm TS 250 79-82 they would need to be 811mm long from axle hole to top of chrome. 78-79 SP370 are very similar, if not the same but I am not sure on the length of those. Also 80-84 DR/SP400/500S are also very similar at first glance but are 836mm long. I am considering a 811mm TS250 set as I would like some fork legs with good chrome, so I am considering them if they are the 811mm long type.
I'll measure them and let you know
