Author Topic: KX Parts For Sale - mostly 84  (Read 6637 times)
Offline Stevo17
« on: January 13, 2015, 04:17:10 pm »
OK, here is a list of parts that I am offering up for sale. Most are for the 1984 KX500 but there are some interchangeable with the 1983-85 KX500 and 1984 KX250.  Prices as listed - there are a couple of pieces of unobtainable in there. Postage is extra.  Please send me a PM if interested and I will get back to you as soon as I can.  Check the part numbers to see if they fit your bike model.
OEM Kawasaki KX Parts - NOS
•   Piston Rings – 13008-5008  $20 (1985 KX250)  SOLD
•   Clutch Plates x 3  - 13088-1055  $25
•   Front Axle Nut/Spacer – 92015-1353  (84 KX)  $25  SOLD
•   Exhaust Muffler Rubber – 92093-1014 $25 SOLD
•   Kick Start Boss – 13061-1007 $80
•   Clutch Release Lever – 13102-1023 $45
•   Footpeg LH – 34028-1104 $40
•   Shock top rubber – 11012-1278 $25
•   Exhaust Muffler Rubber - 92093-1085 $25
•   Seal Cover – 49016-1035 $10
•   O-Rings x 2 – 670B2018 $10
•   Liner – 140081030 $10
•   Throttle Cover – 49006-1097 $50
•   Chain Slider x 2 – 12053-1101 $60 ea
•   Chain Slider – 12053-1144 $60
•   Front Sprocket Cover – 14026-1077 $70
•   Clutch Push Rod – 13116-1107 $35
•   Piston Pin -13002-017 $15
•   Fork Bush x 2 – 92028-1581 $40 pairSOLD
•   Piston Head Insulator (front brake) – 43050-1051 $15
•   Brake Pads – 43082-1027 $50
•   Needle Jet R2 – 16017-1234 $20
•   Brake Caliper Pad Spring – 92081-1341 $20
•   Shock Reservoir Clip – 92037-1375 $35
•   Oil Seal – 92051-005 $5
•   Rear Brake Cam/Spline – 41050-1027 $25
•   OEM Piston Kit 83, 84, 85 KX500 Standard “A” size. Includes piston, ring, pin and small end bearing. Sorry no circlips. $300
•   Head Gasket - 11004-1053 $25
•   Base Gasket – 11009-1288 $10
•   Reed Gasket 84 KX500 4 bolt $10
•   Throttle Cable - 54012-1211 $30
•   Clutch Cable 84, 85 KX500 $30
•   Kickstart Lever 83, 84 KX500 – 13064-5003 $250 SOLD
Non OEM New Parts
•   Rocky Cycle Piston Kit – 83, 84 & 85 KX500. Standard size. $180
•   Clutch Cover Gasket 83-84 KX500 reusable type $20
•   84 Decal Kit Reproduction Graphics $30
Used Parts
•   Complete Clutch 84 KX500 $100
•   Complete Transmission 84 KX500 $100
•   Cylinder 84 KX500 – still has electrofusion bore but signs of wear at the very top rim $200
•   Reed Valve 84 KX500 $60
•   Reed manifold in very good condition $40
•   Stator 84 KX500 – rewound by Small Coil Rewinds $100
•   Flywheel 84 KX500 $40
•   Shift Shaft 84 KX500 $30
•   Clutch cover x 2 – both had repairs.  $20 the pair
•   Crank / Rod in excellent condition 84 KX500 $100
•   Shift Drum 84 KX500 $30 SOLD
•   Kick Shaft / gear  84 KX500 $30
•   OEM RH side cover in very good used condition – 82- 84 KX $30
•   Shock splash guard (white plastic that bolts to frame) 1984 KX500 good usable cond $25 SOLD
« Last Edit: January 15, 2015, 06:42:44 pm by Stevo17 »
Offline mick25
  • Hunter valley NSW
Re: KX Parts For Sale - mostly 84
« Reply #1 on: January 13, 2015, 04:23:45 pm »
Wait till hardo sees all these goodies ;D
« Reply #2 on: January 13, 2015, 05:05:43 pm »
Would you have a kick idle gear?
Offline Stevo17
« Reply #3 on: January 13, 2015, 05:15:48 pm »
Sorry John, that is one of the few parts I don't have.
Offline 84 KX big bore
« Reply #4 on: January 13, 2015, 07:10:35 pm »
Stevo,
Definitely the shock guard. PM sent.
The 85 rings I assume would fit an 84? If so I'd take those too. cheers
c
84 KX 500
84 KX 250
Offline Hardo
« Reply #5 on: January 13, 2015, 07:52:33 pm »
Too right Mick !!   :P :P
Steve, I'll take these parts mate:
Very interested in some other bits - but will take those 2 first please.
Dave.
Offline Ted
« Reply #6 on: January 13, 2015, 08:03:48 pm »
Dave.
Get D to untie your hanky so you can get some more bits ;D
81 YZ 465 H   77 RM 125 B
Offline FireKwaka
« Reply #7 on: January 13, 2015, 08:56:39 pm »
Hey Steve, could you please let me know if you got my PM ? I am struggling with these long winded posts on my phone while on hols.
83 KX500, 83 RM250D, Can Am MX2.
