Author Topic: 1988 -1989 kx 250  (Read 7414 times)
Offline relfy
1988 -1989 kx 250
« on: January 12, 2015, 03:06:02 pm »
WOULD ANYONE HAVE AN 88 or 89 KX 250 THEY ARE PREPARED TO SELL??? CHEERS RELFY
Offline Hardo
Re: 1988 -1989 kx 250
« Reply #1 on: January 12, 2015, 03:25:44 pm »
I have......oh... you said prepared to sell.....  :P :P :P
Great choice there Relfy !
Offline relfy
« Reply #2 on: January 12, 2015, 03:33:19 pm »
That is a nice bit of kit there Hardo ,apart from the year are there any differences between the 88 and 89 models ??
Offline Hardo
« Reply #3 on: January 12, 2015, 04:17:11 pm »
88's in Oz had conventional forks, and the Oz 89's had the 43mm USD's (as mine has above).
Some Pro's reckon the 46mm conventionals (found on 1989 US models) are far superior. You can grab a set and legally fit them.
Ando has an import bike with them on.
I've ridden both and I havent really noticed - but I am just a hacker.
One other difference is the rear shock on the 89 has a fork lower end, whereas the 88's have an eye end bearing.
Oh and the tank is different on the 89's too... it sits lower.
There could be other changes - but I am not really sure. Actually I think the stator is different from memory.....
Other than that mate - just BNG ... lol
Offline bishboy
  • Toowoomba
« Reply #4 on: January 12, 2015, 04:55:01 pm »
I've been thinking about one as my pre 90 bike, there's an 88 on gumtree
http://www.gumtree.com.au/s-ad/victoria-point/motorcycles/kawasaki/1065233804
Offline Marc.com
« Reply #5 on: January 12, 2015, 05:34:22 pm »
Minor detail but my 88 had insert bushes in the sub frame, bitch of a set up as they would seize and spin and then the side covers were permanently fixed..... apart from that mine went well
« Reply #6 on: January 12, 2015, 06:15:22 pm »
89 also has a smoother motor and a twin piston front brake.
If you want to get into train-spotter territory, the rear caliper is different and the 88 rear caliper guard mounts to the swingarm rather than the caliper itself.
I'm slower than Hardo, but I hate the 89 forks - big spike in the midstroke when you least want it.
The 88 forks are lovely once they're set up: Smooth action, fork seals last, and no dramas with the upper alloy tubes corroding. With some Gold Valves in them, they are 99% as good as the best forks I've ever used.
The US-spec 89 forks are even better - bigger cartridge and better base valve design mean there's less need for GoldValves.
Offline Ted
« Reply #7 on: January 12, 2015, 06:31:06 pm »
Ban blue wheels ;D
81 YZ 465 H   77 RM 125 B
« Reply #8 on: January 12, 2015, 06:34:14 pm »
Ban blue wheels ;D
Right while I was admiring it Ted  ;D ;D :)
Offline Hardo
« Reply #9 on: January 12, 2015, 07:51:07 pm »
Hahaha Teddles... 2-1 ....  :-*
Relfy - get one and whack blue rims on 'er mate...   :P
Oh and I am quite impressed.... Nath only really came up with the "Train-Spotter" (LOL!) points!
Offline relfy
« Reply #10 on: January 12, 2015, 07:57:00 pm »
YOU NEED TO BE AT THE FRONT OF THE FIELD TO RUN BLUE WHEELS that's why could never pull it off (bloody mug lair eh TED) lol
