Author Topic: PE250 parts  (Read 1680 times)
Simo63
PE250 parts
« on: January 05, 2015, 10:00:18 pm »
Excellent PE Fuel Tank.  Not sure if this is 175 or 250/400 or even if they are the same thing (someone will know?). I believe it's around 79/80 model (not a part of the other stuff for sale below).  Most of the original stickers, does have fade but an easy clean up, includes cap, mounts and tap $200
PE250 1979 Roller. poor condition but does include front forks (no upper triple clamp), compliance frame, steel swing arm, rusty old shocks, front and rear wheels - $250
PE250 motor (eng number PE250 - 25840). I assume from the same bike?? Does not turn over, NO ignition, good shafts, front sprocket and gear lever still there $150
2 x Kick Starters. Will suit PE250/400. One @ $50 and the other @ $75
Located on QLD Sunshine Coast, can post at your expense.
Offline Phil N
Re: PE250 parts
« Reply #1 on: June 09, 2015, 08:46:02 pm »
Have you still got the Pe kick starters . On sunshine coast too .
Offline Phil N
Re: PE250 parts
« Reply #2 on: June 27, 2015, 08:03:17 pm »
Have you still got these parts or the 400 motor for sale thanks ...phil Sunny Coast.
