Author Topic: Yamaha XT 250 parts needed  (Read 2044 times)
maxvmx
« on: January 02, 2015, 10:25:31 pm »
Hi,
I’m hoping someone with some XT Yamaha bikes surplus to needs can help? I have a fairly late model XT 250 (2 valve model) that I’m after a few bits and pieces for.
Rear brake lever, rod and actuating arm.
Headlight with mount brackets.
Speedometer with mounting plate.
Engine decompression arm and cable.
Stock OEM muffler.
Left and right side handle bar switches
Any help / leads would be most welcome.
Re: Yamaha XT 250 parts needed
« Reply #1 on: January 02, 2015, 10:36:29 pm »
I have one that should have most of those bits, I'm on hols and won't be home till about the 12th of Jan or so. I can check for you then if you like.
I'm up in the Kimberley, so freight might be a bit hexy depending on where you are.
