Author Topic: Yz125h  (Read 4569 times)
Offline maca60
Yz125h
« on: December 26, 2014, 07:01:38 pm »
Hi guys does anyone know if any other model yz125 pistons fit a 1981 yz125h Cheers
Offline Kane Mcguire
Re: Yz125h
« Reply #1 on: December 26, 2014, 07:30:00 pm »
I have a 125h also but can not answer your quest. can you help with getting a brass bush that is in the clutch? mine is flogged out. thanks.
Offline alexbrown64
Re: Yz125h
« Reply #2 on: December 26, 2014, 08:03:47 pm »
There must be a very slight difference as Wiseco lists a different part number for all the piston sizes after 1982 for the 125.  But the same part numbers are used for the rings, clips and pins for all years. They are even the same external dimensions.  You can just go Wiseco for the H as they have a tonne of pistons for it anyway.
Alex
Offline maca60
Re: Yz125h
« Reply #3 on: December 26, 2014, 10:58:09 pm »
There was someone who had a piston kit to fit yz125 from 1976 to 1981 on ebay. I was just wondering if anyone new if these pistons are the same. As for Ricky Stewarts problem my clutch bush was floged out as well but I had an early DT 175 engine and found the clutch bush was the same but just a bit longer and just needed linishing down to the same length. You will probably find all DT yamaha's use the same diameter bush.
Offline alexbrown64
Re: Yz125h
« Reply #4 on: December 26, 2014, 11:24:17 pm »
Well, that case your in luck, as from 76-82 they are all the same part number... http://www.wiseco.com/Catalogs/Powersports/Yamaha.pdf
Alex
Offline maca60
Re: Yz125h
« Reply #5 on: December 27, 2014, 08:37:32 am »
Thanks for your help Alex much appreciated.
