Author Topic: Rebound springs ; 40mm forks  (Read 13495 times)
Offline b490
« on: December 12, 2014, 05:37:53 pm »
 Looking for   rebound springs to suit  Husky   '83 mod 40mm forks .
  Any suggestions  as to where I might find some  most  appreciated .
  Regards ,
                   Steve
Offline HL400
Re: Rebound springs ; 40mm forks
« Reply #1 on: December 12, 2014, 09:00:24 pm »
Get you self a set of Race Tech fork springs they are the best on the market, Part number is FRSP 3452 44  if you are between 80 to 100 kg in weight.    get on to  [email protected] an Ross fit fix you up... HL
« Reply #2 on: December 12, 2014, 09:03:34 pm »
Rebound springs? Keh ???
Offline b490
« Reply #3 on: December 12, 2014, 10:21:44 pm »
 Damper rod / top out springs  is what I am after .
 Regards ,
                    Steve
Offline XC83
« Reply #4 on: December 12, 2014, 10:22:22 pm »
Steve
I think they run a rebound washer rather than a spring. Check your parts book. Frank Pons has some of the washers
Offline PEZBerq
  • Brisbane
« Reply #5 on: December 12, 2014, 10:23:31 pm »
1983 model don't use rebound springs. Use plastic top out washers on top of damper rod instead as hydraulic cushion.
Offline b490
« Reply #6 on: December 12, 2014, 10:49:07 pm »
My 500 forks work  fine  but  250   forks are  clunking when on full  extension from  rebound  ,( no excessive  pre load ) ,  New fork bushes &  dampening rod top out sealing washers fitted  on the 250 .
  Both  bikes  forks have  the top out  springs  fitted to dampening rods  .?  ?
 Regards ,
                 Steve
« Last Edit: December 12, 2014, 10:57:17 pm by b490 »
« Reply #7 on: December 13, 2014, 08:57:09 am »
ive never seen them on a husky. check your washers again, some can fail in 1/2 and hour.
have you centered the damper rods before tightening the bottom bolts?
Offline b490
« Reply #8 on: December 13, 2014, 09:48:55 am »
 Thanks,    I will pull them apart &  have another look at them,   when time permits.
        Regards ,
                    Steve
Offline Ted
« Reply #9 on: December 13, 2014, 04:58:24 pm »
F...the bike EQ. Fix your drainage ;D
81 YZ 465 H   77 RM 125 B
Offline b490
« Reply #10 on: December 14, 2014, 11:03:34 am »
   All   good  now Teddy   , I did the job   8)  ........ so I  didn't have to sell a bike to pay a plumber . ;)
   Regards ,
                    Steve
Offline Ted
« Reply #11 on: December 14, 2014, 07:03:48 pm »
Good on ya ;D because you don't own a bike that would cover a plumbers fee...hahaha
Offline Billet YZ
  • Melton Victoria.
« Reply #12 on: December 14, 2014, 10:48:31 pm »
Lets see if Mr Rice Tack has rebound springs .
Hey Wasp,
                 why do you always feel the need to jump into a post with one of your smartarse shitfaced comments ??  if you really are as good as you tell everyone you are surely you could just reply with some helpful information. It would go a long way.   Peter  ::)
Offline Yamahaha
  • Melbourne Vic
« Reply #13 on: December 15, 2014, 09:46:41 am »
^^^^^^^^  ;) ;D ;D ;D
YZ 250 modern, YZ 125G, YZ 125E, IT 400D, IT 175G x 2, YZ 400F CR250re,  2012 yz450fse Service Honda CR500AF.   Viper #73
Offline ARN
« Reply #14 on: December 15, 2014, 04:43:33 pm »
hi peter
He must of confused it with myss your moto suspension the over price rice version.
As we know RACE TECH sell the original quality product.
