Marketplace
Wanted
1974 Yamaha MX360 front brake cable
Topic: 1974 Yamaha MX360 front brake cable (Read 4092 times)
TJR426
Novice
December 09, 2014, 12:59:37 pm »
Wanted new or used front brake cable for MX360. Thanks
vandy010
#789 MX125a BMCC Brisbane
Re: 1974 Yamaha MX360 front brake cable
December 09, 2014, 03:45:42 pm »
Should still be able to buy one over the counter at your local Yammie shop..
Just check whether the brake backing plate is 6mm or 8mm thread as most early YZ/IT & some DT/XT cables should fit...
Just different lengths is all...
"flat bickie"
BA #63
B-Grade
December 09, 2014, 03:56:57 pm »
Go to steves motocycles he supports your club and he is close to you in
Midland
I am still the fastest in the pits
TJR426
Novice
December 09, 2014, 04:09:20 pm »
Thanks, I will go to Steves, for some reason I thought it would be harder to
find
Tossa
Reply #4 on:
December 09, 2014, 04:17:13 pm »
If not I probably have one. Should have bought my MX360 doesn't need anything!!
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
Slakewell
Slakewell Motordrome
Reply #5 on:
December 09, 2014, 08:21:48 pm »
AG 200 will more or less be the same
BA #63
B-Grade
Reply #6 on:
December 09, 2014, 08:45:18 pm »
except it was not going tossa what was or is the problem with it
Tossa
Reply #7 on:
December 09, 2014, 09:02:56 pm »
Long story but will be fixed this weekend with new piston ring, pin and clips. gaskets. Apparently dropped new ring, I thought it was electrical, but there you go all good
Rossvickicampbell
Reply #8 on:
December 10, 2014, 09:34:23 am »
never said you were a mechanic!
Tossa
Reply #9 on:
December 10, 2014, 09:51:36 am »
Nice Rossco, thank you for your support!!lol
BA #63
B-Grade
Reply #10 on:
December 10, 2014, 10:27:42 am »
mrT (mr tossa) that husky is nearly two full bikes I will go look this week hoping the one motor is a wr
Tossa
Reply #11 on:
December 10, 2014, 12:47:05 pm »
where is it
Marketplace
Wanted
