Author Topic: Maico 490  (Read 4960 times)
Offline scottm
Maico 490
« on: December 08, 2014, 09:03:10 pm »
Can anyone tell me if the rear brake backing plate on a 82 model is the same as an 83 , also is the airbox the same
cheers Scottm
pre 84 thank you very much
Offline MauriceR
Re: Maico 490
« Reply #1 on: December 09, 2014, 04:26:13 am »
Nope 82 backing plate was a 1 year only, airbox is also different
Offline KTM47
Re: Maico 490
« Reply #2 on: December 09, 2014, 11:04:21 am »
The rear wheel, brake and backing plate are slightly different between 78/81 and 82/83.  Maico Only make a billet backing plate to use the 82/83 wheel in a 81.  The difference is just a matter of spacing the wheel so the sprockets line up.  Air box for 82/83 was for a single shock bike totally different.
MAICOS RULE DESPITE THE FOOLS
Offline scottm
Re: Maico 490
« Reply #3 on: December 09, 2014, 06:41:55 pm »
So a spacer and 82 rear backing plate can be used ?
Offline KTM47
Re: Maico 490
« Reply #4 on: December 10, 2014, 02:17:58 pm »
Yes.  Just measure the distance from the sprocket face to the part of the backing plate that sits against the swingarm on both wheels and make it the same.  I think there is about 3 mm in it.
Offline scottm
Re: Maico 490
« Reply #5 on: December 10, 2014, 06:11:41 pm »
       Thanks very much gents, I will measure once installed
