Author Topic: Honda thread pitch sizes  (Read 9053 times)
Offline Kenneth S (222)
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
« on: November 30, 2014, 08:05:34 pm »
Hi Guys,
My recent purchase, an 89 Honda CR250RK had one of the front fender mount holes stripped out. I have had the hole filled and now want to re drill and tap it. It is a 6mm bolt. Firstly, Does anyone know what the standard thread pitch is? I have a 6 x 1mm tap which seems to match the bolt, but it doesn't easily screw into one of the other holes.
Thanks,
Kenneth
« Last Edit: November 30, 2014, 08:10:13 pm by KJS222 »
Kenneth S
Go For It
Race Bike History
Offline Paul552
  • HEAVEN #552
Re: Honda thread pitch sizes
« Reply #1 on: November 30, 2014, 08:16:48 pm »
M6 x1 for sure mate
Pre drill 5.0
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
« Reply #2 on: November 30, 2014, 08:18:15 pm »
M6 x1 for sure mate
Pre drill 5.0
Kenneth S
Go For It
Race Bike History
« Reply #3 on: November 30, 2014, 08:34:16 pm »
For some reason the tap sizes are tight in alloy cases .... if you run a STD  tap they are too  loose and will strip out easy.
« Last Edit: November 30, 2014, 08:59:55 pm by oldfart »
« Reply #4 on: November 30, 2014, 08:57:46 pm »
My experience is that machine tapping generally gives a tighter thread, possibly due to only 1 tap used & the tap is held steadier by the machine
« Reply #5 on: November 30, 2014, 10:42:16 pm »
Like a spoke threads in aluminium should be cold forged NEVER cut, that makes the thread weak. Good news is forging taps are cheap on ebay. They are a worthwhile addition to the toolbox as they can be used to repair a thread.
http://www.ebay.com.au/itm/HSS-Thredflo-Fluteless-HAND-TAP-M6-X-1-0-SUTTON-/191265412132?pt=LH_DefaultDomain_15&hash=item2c884e9424
Offline Momus
« Reply #6 on: December 01, 2014, 05:09:54 pm »
Quote from: oldfart
The crankcase half and side cover threads on bikes are usually a standard M6 thread.
The threads that highly stressed fasteners, like studs, screw into are generally made with a carefully toleranced undersized tap to give a tighter fit.
There is a series of special taps to take account of this.
I use the 'Threadflow' fluteless taps that Lozza mentioned a lot at work. The tapping hole is drilled larger than for a cutting tap. The tap is wound in the normal way and displaces the aluminium (or steel or stainless steel) cold forming the thread. This gives a high strength slightly work hardened job with a good finish. There are no chips produced so this method is very safe for blind holes. These taps are quite a bit stronger than the usual type because the minor diameter is greater. The taps are more expensive but well worth the extra for fine work.
« Last Edit: December 01, 2014, 05:12:23 pm by Momus »
If you love it, lube it.
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #7 on: December 01, 2014, 05:42:52 pm »
Excellent advice.  ;D
Offline mick25
  • Hunter valley NSW
« Reply #8 on: December 01, 2014, 05:51:58 pm »
When I first had a go at redoing threads I got a scrap peice of 10mm thick alloy plate and done a few practice runs first ;) best to get it right the first time on the job you are doing  8)
Offline Paul552
  • HEAVEN #552
« Reply #9 on: December 01, 2014, 06:13:24 pm »
If you are going to use a flute less tap that pre drill will be different for a roll thread
« Reply #10 on: December 01, 2014, 06:44:55 pm »
You really can't beat a rolled thread......but when in a pinch it seems the fluteless tap will do the job
« Reply #11 on: December 01, 2014, 09:41:17 pm »
Normaly a cut thread drill size is 5mm for a M6 thread a formed thread the drill size is 5.5mm. Think it is normally almost the root diameter for cut thread and half that for a formed thread
« Reply #12 on: December 01, 2014, 09:57:32 pm »
Use a bit of kero as a lubricant too. J
« Reply #13 on: December 02, 2014, 08:48:26 am »
I use sewing machine oil to start and WD or similar to clean the schwarf away.
« Reply #14 on: December 02, 2014, 09:16:47 am »
Bit like sex. Anything will do at a pinch! J
