Author Topic: Coolant  (Read 3598 times)
Offline CRTAD313
Coolant
« on: November 16, 2014, 05:50:42 pm »
We all know of the early Honda cr water pump problems. Question is if you have a good case which coolant will prevent/lessen the corrosion onset?
Offline PEZBerq
  • Brisbane
Re: Coolant
« Reply #1 on: November 18, 2014, 01:48:53 am »
Waterless coolants are quite effective. There is a local Australian product called Liquid Intelligence 115 that I use in my magnesium Husky barrel which seems to have stopped the rot. Not cheap however at $50 per litre but better than the alternative of drain and dry out after every ride. Evans make a waterless coolant also I believe.
Offline CRTAD313
Re: Coolant
« Reply #2 on: November 19, 2014, 06:43:31 pm »
Thks , yep not cheap . But better than trying to replace hens teeth.
Offline 2stroksmoka
Re: Coolant
« Reply #3 on: November 20, 2014, 06:50:42 am »
I just put engine ice in my 89. Looks like the the water pump etc is in pretty good shape. Should I be using something different in my old bike? I assumed it was just a case of coolant was crap back in the 90's?
