Author Topic: Will a Mk3 Pursang motor fit a Metisse?  (Read 6452 times)
Offline farmer58za
« on: November 16, 2014, 07:23:51 am »
Hi All
Whilst looking for a '65 Mod 11 Metisse motor, I came across a peachy '68 Model 48 Mk3 Pursang motor. Apart from the side port cylinder, will the later Pursang cases bolt straight into the Metisse frame?
Thanks in advance
David
Dave's not here man
Offline cemotobull
Re: Will a Mk3 Pursang motor fit a Metisse?
« Reply #1 on: November 16, 2014, 08:14:54 am »
4 speed motors like the original model 11 pursang have 3 engine mounting bolt holes. 5 speed motors have 4 mounting bolts. You will get the the engine bolts through the top 2 mounting holes front and back of the mk3 motor but you would have to modify the frame with 2 mounting tabs for the bottom mounting holes (front and back of the engine). You will also have an issue with the exhaust hitting the twin down tube on the métisse - therefore you would have to have an extreme bend on your exhaust or mod the frame!
Offline farmer58za
« Reply #2 on: November 16, 2014, 04:08:25 pm »
 :-\ Ok, pity. I don't want to change the frame!
Regards
David
Dave's not here man
Offline farmer58za
« Reply #3 on: November 27, 2014, 08:25:55 am »
Mocked the Mk 3 motor up in the Metisse frame and it'll be a bridge too far! Nearly breaks my heart as the mk 3 motor is really good. Was set up as a kart motor but has been well maintained.
So it's back to kissing frogs............
Dave's not here man
Offline bullmad24
« Reply #4 on: November 28, 2014, 09:33:21 am »
How good a welder are you farmer58za I have a set of  m 11 cases a barrel and head but they will need a fair bit of work ?
Offline farmer58za
« Reply #5 on: November 29, 2014, 09:08:42 am »
Bullmad24
I'm no welder so I  give my work out to a specialist who will weld up most things. Please contact me
farmer at global dot co dot za
Regards
David
Dave's not here man
