Author Topic: 1980 and 1981 swingarm  (Read 9884 times)
Offline MauriceR
« on: November 14, 2014, 07:23:43 am »
does any body have the exact lengths of the 1980 and 1981 Maico swingarms
Offline Ktm181
Re: 1980 and 1981 swingarm
« Reply #1 on: November 15, 2014, 10:51:27 am »
Hi Maurice,
MC250 '81 is 605mm length (23 & 3/4 inches), that's outside leading edge of front pivot to outside of trailing edge of the rear, make sense?
Cant help with the '80 although I have been told its shorter, the '78 Mc400 I have is nearly 50mm shorter from memory.
regards,
Wayne
« Reply #2 on: November 15, 2014, 01:22:12 pm »
Hi Maurice,
The 81 swing arm is only common to that Mega Two model.
Where as Part #6207 is common to 1980 MC and 1979 MC range only.
I don't know what difference/s causes the 78 arm to have a different part number from the 79/80 arm?
Although I do have a smick 78 and I am picking up a 79 frame and arm within the next week or two :) ;)
« Last Edit: November 15, 2014, 01:28:20 pm by Mick D »
Offline MauriceR
« Reply #3 on: November 16, 2014, 11:32:37 am »
Wayne how are you, did you get any time on that 250 this year, I want to change the swingarm on my 78 and was told a 1980 is longer and helps but every measurement I have found they are only 3mm longer so can't see the point of using an 80, I think I will find an 81 swingarm and have already found a set of 81 forks modified to 10.5" travel.
Mick i thought the 80 and 81 only had the newer style chain adjusters but was told that some of the 79s had them also so maybe thats why the different number, i know there is 1/8" (3mm) alsodifference between 78 and 80
« Reply #4 on: November 16, 2014, 12:11:07 pm »
I notice the GS arms have different part Numbers Maurice, I thought it was only the mounts for the inner chain guard and holes to mount the center stand rollers, but maybe there might be a chain adjuster thing as well?
I am just about to stick a 81 arm on my 78 as well ;D its still sitting beside the bike ::)
I am also setting up a reed 250 engine for it.
An optimized and well built 81 250 reed engine is one of greatest things that ever came from Germany :)
« Reply #5 on: November 16, 2014, 12:57:41 pm »
My head innards are crowded ;D
I just checked my 78, yes chain adjuster is a carry over from the AWs etc.
I knew that ;D
My 78 is a well set up sweet ride, but I like the 81 better,,,,
I can hardly wait to see what  a difference the 81 engine and swing arm make to the 78 ;D
« Last Edit: November 16, 2014, 01:03:42 pm by Mick D »
Offline MauriceR
« Reply #6 on: November 17, 2014, 05:39:06 pm »
mick not sure if you do facebook but there is a Maico parts wanted or for sale group that a guy posted (richard Fogel) pics of
his 78 with a 81 arm and forks and he said he used a  honda reed valve setup that you might be interested in
« Reply #7 on: November 17, 2014, 05:44:43 pm »
WARNING THREAD HIJACK. I have an RM250A motor sitting nicely in a a 77 frame. Obviously I have to change the rear wheel around not to mention modifying the barrel to centre port. Should keep me occupied for the rest of my life! J
« Reply #8 on: November 17, 2014, 05:59:56 pm »
 ;D ;D ;D ;D ;D ;D
projects hey Jerry ;D ;D ;D we seem to be gluttons for it ;D ;D ;D :o
« Reply #9 on: November 17, 2014, 06:08:21 pm »
None of this is my fault. I stumbled onto the Maico after striking up a conversation with a random stranger and the Matt my neighbour gave me the RM engine. A couple of beers later ............ J
« Reply #10 on: November 17, 2014, 06:11:37 pm »
Its truly amazing just how close the makings of the project can be :) Good luck Jerry 8)
his 78 with a 81 arm and forks and he said he used a  Honda reed valve setup that you might be interested in
Thanks for the tip Maurice but so far I have managed to resist face book,,,not quite sure whether that is a good or bad thing.
Many years back I slightly elongated the holes on a 79 Honda Reed to carby adapter, so I could fit a 38mm
 Mikuni to my 81 250.
I altered the cage and reed arrangement.
Then played around with spacers.
I gradually altered the all the jetting that came in the Mikuni kit.
The contrast from the bog standard reed and Bing is mind boggling.
I have never tried a VEE-FORCE, but would love to.
I would also love to score a set of 79 38mm forks for my 78.
« Last Edit: November 17, 2014, 07:10:43 pm by Mick D »
