Author Topic: yz v it 465 shock length , any difference?  (Read 2911 times)
lms6201
« on: July 11, 2008, 06:01:28 am »
  would anybody have the eye to eye length of the yz 465 shock please , i have an it 465 unit in great condition and was hoping to use it , is there much difference ?   thanks
Re: yz v it 465 shock length , any difference?
« Reply #1 on: July 11, 2008, 12:43:06 pm »
Can't talk with authority on the 465s, but the IT250J shock has a longer spacer in it that shortens the total shock length (and limits travel) compared to a YZ250G shock.
FWIW, The IT175H shock is the same basic thing again, but with an even longer spacer.
The spacer is easy to shorten down when the shock is apart, but I can't give you any useful measurements.
Offline TonyB
« Reply #2 on: July 11, 2008, 03:33:09 pm »
I just had my spacer under the piston  removed from the IT 465 shock its about 12-13mm long which equates to about an inch of wheel travel. I also had the collar which holds the piston above it machined, which gets another 6mm piston travel or half an inch wheel travel. Now I got aprox 12,5 inches. I also had a late model piston fitted but it has been very difficult to achieve the correct compression damping. I prefer very little comp damping to allow the wheel to rise up quick on brake bumps and square edged holes. Its pretty good now but could do with a little less comp damping still. Its taken 3 adjustments (opening shock and removing shims etc) to get it where it is now. One more time and i recon i will have a good valving setup, then I want to get a progressive spring wound so that the first half is plush and compliant and the second half is stiffer for the bigger jumps.
'Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways,totally worn out, shouting,  ' Holy sh!t... What a Ride!! ' '
YSS
« Reply #3 on: July 11, 2008, 04:14:49 pm »
What type of piston did you use ?
Offline TonyB
« Reply #4 on: July 11, 2008, 10:41:54 pm »
heavilly modified yz450 piston, but its action is not much better than the stock 1981 one, untill I get that last bit of comp damping out.
lms6201
« Reply #5 on: July 12, 2008, 07:24:41 am »
so the shock lenght difference between the it and yz , is it much ?
Offline TonyB
« Reply #6 on: July 13, 2008, 06:14:49 pm »
about 12mm (IT shorter than YZ)
