Author Topic: Yz465 h front brake  (Read 8076 times)
Offline yamaha nut
Yz465 h front brake
« on: November 10, 2014, 08:55:34 pm »
Hi guys I just purchased a low hour 465 h matching numbers but after the fact I've realised it only has a single pull front brake not the twin leading as you would expect anyone seen this before
Offline Ted
Re: Yz465 h front brake
« Reply #1 on: November 10, 2014, 09:52:24 pm »
Is it a 1980 G model
81 YZ 465 H   77 RM 125 B
Simo63
« Reply #2 on: November 11, 2014, 12:14:34 am »
Is it a YZ or an IT?
What are the first 3 digits of the frame and engine number?
If it's a 1980 G Model YZ then it will be 3R5
If it's a 1980 G Model IT then it will be a 425cc and the code will be 3R8
If it's a 1981 H Model YZ then it will be 4V4
If it's a 1981 H Model IT then it will be a 465 and the code will be  4V6
The brake backing plates of many of the non-linkage (ie monoshock) YZ and IT Yamahas are interchangeable and many have been robbed of parts along the way :)
Hope this helps :)
Offline Ando
« Reply #3 on: November 15, 2014, 06:13:28 am »
Someone has robbed it, both the YZ465G & YZ465H came standard with twin leader.
« Reply #4 on: November 16, 2014, 04:23:11 pm »
Bit of a slap in the face, when some grub steals ya front brake but leaves the rest behind ;D ;D ;D
Offline mick25
  • Hunter valley NSW
« Reply #5 on: November 16, 2014, 05:17:49 pm »
Even gets worse have a look on eBay for one $200 up wards  :-[    The 80 , 81 brake plate can be used on diffrent Yamaha models that's why the price is high.
You may be lucky and find one that someone doesn't no what they are worth good luck but..
Offline smed
« Reply #6 on: November 16, 2014, 06:10:50 pm »
As far as other models having the same backing plate, I done some research a while back & it's all a bit confusing,going off online fische which may be wrong :-\ or optional parts,maybe different markets had different specs but YZ125K&L,IT465J&K,YZ250G&H?? show up as the same part number,beware there are two different twin leader backing plates ;),This is the one for the YZ465H forks :)
Note the upper brake shoe pivot cam right next to the fork lug,the other type off YZ490/TT600 etc is a long way apart ;)
« Last Edit: November 16, 2014, 06:31:24 pm by smed »
Offline smed
« Reply #7 on: November 16, 2014, 06:13:41 pm »
Oh yeah,Forgot that the YZ465H had fabricated steel brake arms & the YZ125K/L had cast alloy,or was it the other way round :-\
« Reply #8 on: November 16, 2014, 06:23:05 pm »
Alloy on the 465 .
« Reply #9 on: November 16, 2014, 06:55:03 pm »
I don't agree with that Iain.
Although they are interchangeable, and a lot of them been changed ::)
My YZ/IT were already a year or two old when purchased.
But the YZ465G I had in the day still had punched, pressed and spot welded steel ones on it,,
So did the IT465H.
I believe the forged alloy ones did not arrive till the K models
The parts lists also support those memories.
« Last Edit: November 16, 2014, 07:35:08 pm by Mick D »
« Reply #10 on: November 16, 2014, 07:03:56 pm »
Correct, my 465 had the steel brake arms & I picked up a 490 backplate just to get the alloy arms. The hole for the brake cable pin is smaller in the alloy arms so it needs opening up to use the 465 cable
Offline mick25
  • Hunter valley NSW
« Reply #11 on: November 16, 2014, 08:05:47 pm »
The yz465 plate fits straight on the tt500 models f , g ,h models with no mods , front wheels are the same . fork brake lug in right spot.
The 465 plate may fit other Yamaha bikes for better brake power.
« Reply #12 on: December 10, 2014, 07:41:31 pm »
Ok I stand corrected the 4 odd H's Ive collected over the years have all had alloys arms . learn something new every day . Iain
Offline Ando
« Reply #13 on: December 11, 2014, 06:32:57 pm »
G & H's steel, first of the alloy was on the J model.
Offline matcho mick
    • Moto Tumbi
« Reply #14 on: December 11, 2014, 11:17:48 pm »
5X600 82 YZ490,bugger i can't use it in evo  ::),it's off watercooled forks, :P
ps pressed steel spot welded arms too
