Author Topic: 84 rm 125  (Read 4322 times)
Offline Tim37
  • Its an investment ...had to buy it !
84 rm 125
« on: November 09, 2014, 09:12:47 am »
Hi just taken delivery of an 84 Rm 125 E it's the usual ebay interstate bike " it just needs first gear fixing " when in reality it's a total scrapper every bush & bearing in the full floater is rooted , rusty spokes mashed pipe ... However I don't see many of these about . I raced one in 85/86 it was a great bike on rough tracks but I could never make it run with a Honda on outright HP .. Should I rebuild the front wheel and put the 43 mm TLS front end into my 125 x which is restored and flys or restore this e ???
Offline SUZUKI311
Re: 84 rm 125
« Reply #1 on: November 09, 2014, 12:24:05 pm »
Put the 43mm front end in the X, and you will have an unreal machine.. ;)
Offline alexbrown64
Re: 84 rm 125
« Reply #2 on: November 10, 2014, 08:02:03 pm »
Ive had the same thing recently with my 79 model RM80N.  Take a deep breath.  You now have the bike you used to race back in the day.  For now, put the front end on your X, then turn the E into a project.  Put it to one side for now while you plan it all out.  Sometimes the disappointment of a Fleabay bike buy gets to you but after a while you can turn it around and make a fun project out of it.  See my RM80N Roach project in the Suzuki forum. Heres the brochure for your old girl.. https://onedrive.live.com/?cid=407D7EF0965D3991&id=407D7EF0965D3991!4171
Alex
Offline D project
Re: 84 rm 125
« Reply #3 on: November 11, 2014, 01:09:14 pm »
I've got both bikes. The X has been bullet proof and the E nothing but problems. Saying that though the X was a low hour bike and the E had been flogged. You'll find the E a lot harder to get parts for but the linkage bearings are the larger type and cheaper. Rear shocks are usually flogged out as well compared to the X which runs the bigger shock. I'm onto my third gearbox, it's usally second gear that goes as its only a press fit on the shaft. If you need to replace it go for the 85 as its a stronger close ratio box. You'll also need the 85 shift forks otherwise it's a easy change over. Power wise the E is stronger but the X has a better spread.
The front end swap is a good option. You can also run the front wheel off the X.
Offline matcho mick
    • Moto Tumbi
Re: 84 rm 125
« Reply #4 on: November 11, 2014, 10:25:41 pm »
you might want to requalify "press fit",make it 'shrink fit",& your gearbox(shaft) will thank you, :P
Offline suzuki59
  • Kiwi VMX
Re: 84 rm 125
« Reply #5 on: November 12, 2014, 12:14:31 pm »
Yes,what D project said-I have owned both-the X has nice punchy bottom mid power the E is a topend screamer.
The x is smaller and more suited to the vertically challenged,whilst the E sits taller.
Both are cool bikes and Suzukis are still reasonably good to get parts for NOS.
Have fun deciding!
Offline alexbrown64
Re: 84 rm 125
« Reply #6 on: November 13, 2014, 09:03:22 pm »
Offline Tim37
Re: 84 rm 125
« Reply #7 on: November 16, 2014, 10:40:41 pm »
Thanks chaps ! I have another 84 tls front end on the ways and will fit it to the 81 , my  81 is well modified and revs to the moon , twin air airbox , small body 32 mikuni bored to 35 , DG pipe & silencer , ports matched .
The 84 will get oiled up and reboxed for a while .   I love the 81 as I had two new ones that year , a big off wrecked the first one beyond economic repair ....
I will post pics when the 43 mm tls is fitted . cheers
