Author Topic: PE 175  (Read 4274 times)
PE 175
« on: November 03, 2014, 05:50:48 pm »
Mate needs a gear shaft for an 82 PE 175 (usual story, some one welded the gear lever on)
Any leads appreciated.
Part # = 25510-405V0  & also Part # = 25510-40500
Part Description = SHAFT,GEAR SHIFT
Model Count = 8
PE175D 1983 172 PE175 DUAL PURPOSE
PE175E 1984 172 PE175 DUAL PURPOSE
PE175T 1980 172 PE175 DUAL PURPOSE
PE175X 1981 172 PE175 DUAL PURPOSE
PE175Z 1982 172 PE175 DUAL PURPOSE
RS175T 1996 175 RS175 DUAL SPORT
RS175X 1981 175 RS175 DUAL SPORT
RS175Z 1982 175 RS175 DUAL SPORT
P
HeavenVMX
Re: PE 175
« Reply #1 on: November 03, 2014, 07:07:04 pm »
They are still listed as available from Suzuki
Offline mick25
  • Hunter valley NSW
Re: PE 175
« Reply #2 on: November 03, 2014, 08:44:53 pm »
A mate was chasing one the same but he said he couldn't get one new   :-\
Maybe he was looking in the wrong place , he ended up getting a good second hand one.
I did say to him if he couldn't get one he could get one  from another Suzuki model or other brand bike and make sure it's long enough and right diameter and cut it down to the same length as yours then weld it to the bracket from your old shaft.
It would be better not to use a Suzuki one because they have a large spline tooth and makes it limited for gear stick choices, other brands bikes have a fine spine and more choice of gear stick lengths etc
« Last Edit: November 03, 2014, 08:47:34 pm by mick25 »
HeavenVMX
Re: PE 175
« Reply #3 on: November 03, 2014, 08:50:41 pm »
I've had a lot of luck with these guys in the US and are great to deal with
http://www.partshark.com/oemparts/a/suz/50d3a0d3f8700229982f4c0e/gear-shifting
Also try Suziparts in SA they are also excellent. Google it
Re: PE 175
« Reply #4 on: November 03, 2014, 08:54:45 pm »
He tried one of the US mobs already, they took his money then couldn't supply.
I told him to try Suzuki direct but any good second hand ones considered.
What other Suzuki's come close?
I would have thought an RM 125 but they are different part No's!
He has one from a different model but it is shorter not longer.
Offline mick25
  • Hunter valley NSW
Re: PE 175
« Reply #5 on: November 03, 2014, 09:02:17 pm »
My mate tryed alpha sports but no luck.
I did give him suzi spares ph number but I think he didn't have one but don't count on my memory.
« Last Edit: November 03, 2014, 09:04:28 pm by mick25 »
Offline yamaico
Re: PE 175
« Reply #6 on: November 04, 2014, 12:14:28 pm »
I've fixed plenty of gearshafts with a cut and shut:
Happy to do your mate's one for the cost of postage if he's stuck Geoff,
Pete.
Re: PE 175
« Reply #7 on: November 07, 2014, 02:55:09 pm »
Thanks Pete
I had thought of welding a new end on but was concerned about alignment, especially with the seal, that's a neat way you have of doing it.
I will chase him up next week to see how he got on Suzuki.
Re: PE 175
« Reply #8 on: November 08, 2014, 01:52:15 am »
I use petes joint ;) method to make long drills and use high grade silver solder on the joint
Offline yamaico
Re: PE 175
« Reply #9 on: November 09, 2014, 08:04:41 pm »
I use silver solder on my extension drills too Matt. Incredibly strong on a capillary joint like that. Would be ideal for a gearshaft as well, good thinking.
Thanks Pete
No worries Geoff. Not sure about the PE's but a lot of Yamaha's have the actual selector arm on a spine which makes it really easy to strip and set up in the lathe for boring.
