Author Topic: honda 1973 cr250 tapered stearing head bearings  (Read 1727 times)
« on: November 02, 2014, 08:14:31 am »
hi
is it hard to change over as I have a set and seals that were in a bunch of cr parts I got but no instructions
jim
Offline smed
Re: honda 1973 cr250 tapered stearing head bearings
« Reply #1 on: November 02, 2014, 08:30:01 am »
No, Easy ;) just tap out old outer races from frame & inner race off bottom clamp like normal & fit the new stuff, two things to be wary of though is the upper & the lower may have different I.D.s so measure em up before fitting & some early Allballs kits were not right & had the wrong I.D. in either the top or the bottom,dunno if other kits were also stuffed up but worth checking first :)
