Author Topic: Yz465 h...why is my clutch slipping  (Read 18885 times)
Offline smed
Re: Yz465 h...why is my clutch slipping
« Reply #15 on: October 24, 2014, 11:09:56 pm »
Having an extra steel (Which is wrong) without an extra fibre (which is also wrong) would be the same as having the correct amount of steels except one would be double thickness of the others ;)
Which would have the effect of tightening up the clutch pack therefore preventing slipping, This would fix the problem but not the cause, Something is wrong or worn with the adjustment, assembly or the plates themselves :)
« Reply #16 on: October 24, 2014, 11:57:05 pm »
Steel against a steel is fine, done it before.
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #17 on: October 25, 2014, 08:34:57 am »
Has the basket got wear grooves in the fingers?
Binding/restricting the plates from correct movement?
"flat bickie"
Offline Doc
« Reply #18 on: October 25, 2014, 08:44:30 am »
Missing the obvious, due to the internal splines the steels always turn together, they never spin against each other.
yup..missed the obvious Geoff, if it were a snake it would have bitten me ::)
Offline POM
« Reply #19 on: October 25, 2014, 09:25:54 am »
Basket is very good condition.....pressure plate does have a bit of a wear lip on it hence the extra steel plate did not sit well against it....
Cable,operating lever,and push rod assy all seem good also......all a complete mystery.
However it seems to be ok now with the extra plate.....several clutch abusing starts up and down the street proved that.....neighbours just love me lol
« Reply #20 on: October 25, 2014, 12:13:21 pm »
If there is a lip on the pressure plate etc then that gives less contact area which could be your problem, having to use an extra plate just doesn't sound right
« Reply #21 on: October 25, 2014, 01:03:11 pm »
Have tried extra steel plate (in different positions).....still no good.
All the steels are like new.......
All the fibres are old.....but as i said measure up ok...all very odd
yer but what are the spring free length lengths are they in tolerance?
if the spings have lost length and preload, there's ya problem
pressure plates not worn?
Offline smed
« Reply #22 on: October 25, 2014, 01:18:11 pm »
Fine maybe, If it gets you out of trouble,But not correct ;) A clutch is designed to have x amount of plates, any more or less to make it work means something is wrong ;)
The only exception to this is some aftermarket kits have one each extra but they are all thinner to still achieve the same stacked height, Only available for moderns I think though,something to do with giving better feel or hookup from memory :)
What may tell us more is details such as, Did the clutch slowly start slipping over time when previously all was good & untouched or has the motor been apart & rebuilt or the clutch assembly been removed & replaced or any part of the clutch from the lever down, one example is, Some bikes have a ballbearing inside the mainshaft between the pushrods if it is left out the clutch will not disengage, If the ball is too big it will hold the pressure plate too far out & the clutch will slip,I have also found two balls in there in some motors :o, Only one of many things it could be though along with what others have said  :)
Offline mick25
  • Hunter valley NSW
« Reply #23 on: October 25, 2014, 05:00:34 pm »
The pressure plate has to go in one way other wise there is a gap between the last plate and pressure plate.
I found this out when putting a Yamaha one back in you have to turn the pressure plate around on on the diffrent studs for it to drop right down , because I through i left a plate out but it was the pressure plate sitting In wrong.
This might be the prob or not. That's why you can fit an extra plate in because the pressure plate is in wrong.
« Last Edit: October 25, 2014, 05:05:29 pm by mick25 »
Offline smed
« Reply #24 on: October 25, 2014, 06:13:07 pm »
Yep, That is another one that catches a few out,some bikes have a dot on the inner basket & an arrow or dot on the pressure plate to line them up,otherwise you just have to keep trying & turning the pressure plate on each one until it goes all the way on ;) :)
Offline Boyracer
« Reply #25 on: October 30, 2014, 10:44:46 am »
Buy a new genuine set up.
Offline POM
« Reply #26 on: October 30, 2014, 06:04:15 pm »
HERE IS THE ANSWER........
The clutch pack in this bike is very generic between models 250/465 from 77-81...I knew that...and wrongly assumed every part was the same.....ohhhhh nooo......after a lot of head scratching i read the fine print in the parts list.......the springs are different between 250 and big bore.....it seems i had some 250 springs in it ( which measure up the same as 465)....some decent springs and all good.
« Reply #27 on: October 30, 2014, 08:16:24 pm »
the fine print..... >:(
« Reply #28 on: October 31, 2014, 10:27:12 am »
now do you believe me
