Author Topic: Still more.  (Read 2835 times)
Still more.
« on: October 21, 2014, 12:27:13 pm »
43mm disc forks, wheel & bottom triple, matser cyl & hose (I think Yamaha, has speedo drive) fork tubes good nick. $100
YZ250K ('83) triple clamps $75
1981 CR125 frame, air box, 1 radiator.  $50
1980 PE400 frame with compliance plate, rear loop removed $100.
Kawasaki unitrack swing arm (KDX200 air cooled) $50
CR480 swing arm (not sure if '82 or '83) $50
1982 KX250 swing arm $50
RM100 cylinder/head/reed block ('79 I think) $100
Couple of Husky 390 cylinders & heads '77-'79. Cylinders $100 each, heads $50 each
Husky 250 cylinder '78-'81 $100
1985 KX125 43mm forks & triples $150.
1974 (I think) XL 350 forks $50
Lots of steel handlebars $5 a set..
YZ465 air box with air boot $50
Couple of CR480 air boxes with air boots $50each.
Box of KTM USD fork stuff, has disc brake bottom clamp. Could probably make 1 set $50.
« Last Edit: October 23, 2014, 07:57:47 am by bigk »
Re: Still more.
« Reply #1 on: October 21, 2014, 07:46:59 pm »
Any chance if a photo of the possibly Yamaha 43mm front end?
Re: Still more.
« Reply #2 on: October 21, 2014, 10:52:02 pm »
Send your email address & I'll send some through.
Offline Andrew L
Re: Still more.
« Reply #3 on: October 21, 2014, 11:17:42 pm »
PM sent Cheers Andrew
Re: Still more.
« Reply #4 on: October 22, 2014, 08:53:47 pm »
Npsenior
@yahoo.
Com.au
