Author Topic: Sloppy hub bearing hole  (Read 4760 times)
Offline Paul552
  • HEAVEN #552
« on: October 10, 2014, 10:40:41 pm »
I have a hub and the bearing hole is not tight on the bearing anymore.
I was thinking loctite or centre punch the hub.
Is there any other methods you guys have for this problem??
I am interested in you ideas ;D
Offline Tomas
Re: Sloppy hub bearing hole
« Reply #1 on: October 10, 2014, 11:13:39 pm »
you can machine the hole bigger and have a steel insert/sleeve pressed in.
« Reply #2 on: October 11, 2014, 12:09:05 am »
if the hole is not egged out too much you can use steel shim or an old feeler gauge to take up the slack. put the shim in most of the way then work the bearing in ;) could be used in conjuction with lock tight as well
« Reply #3 on: October 11, 2014, 08:00:15 am »
See if you can get a bearing thats 1mm bigger OD
You maybe able to use a thing called a speedy sleeve available at bearing shops. You can buy some shim steel but thats not a real long term solution. Locktite is only good for up to 15 thou. I would not center punch it.
Offline Canam370
« Reply #4 on: October 11, 2014, 08:08:00 am »
I've used Devcon's Aluminium Putty as a filler with some success. You could give any epoxy resin a go - just make sure its gone off before you load up the bearing and don't use so much that you glue up the bearing!
Offline Berwick Boy
« Reply #5 on: October 11, 2014, 10:07:20 am »
This thread's title needs censoring!
Offline BA #63
« Reply #6 on: October 11, 2014, 11:22:44 am »
good welder and machine shop   bore out bigger then weld up and machine back to size  if the hub is magnesium a bit trickier for some if you can get a good second hand hub for around  $100 go that way   or slightly bigger bearing if enough meat in bearing housing to machine out            cheap way  sleeve will work as well but press fit then machine to size
I am still the fastest in the pits
« Reply #7 on: October 11, 2014, 11:52:54 am »
Speedy sleeves are for worn shafts not for worn bearings recesses, the product for that purpose is called a tolerance ring which you bore the damaged housing out to fit, it has flat serrations on it that get flattened out by the bearing when you fit it & these help it to grip better
http://www.mcmaster.com/#tolerance-rings/=u3ihsz
« Reply #8 on: October 11, 2014, 06:14:35 pm »
Yeah was going say "don't bother with the KY Jelly"  but I shall not now....
