Author Topic: engine clean up while in one piece  (Read 4817 times)
« on: September 28, 2014, 07:40:20 pm »
does anyone have any tips for cleaning up the cases on a bare alloy engine while it is still together?
I've got a vey low hour RL250 motor which seems mechanically sweet but is pretty grubby externally. If I have to split the motor to clean it up I will, but I was wondering if anyone has any magic wand technique for cleaning something like this up while it's together?
Re: engine clean up while in one piece
« Reply #1 on: September 28, 2014, 07:49:41 pm »
AliBrite.
Offline Turtle.Inc
« Reply #2 on: September 28, 2014, 07:55:37 pm »
The original purple polish
Always looking for Maico parts/bikes, cash paid
« Reply #3 on: September 28, 2014, 07:58:39 pm »
Stay away from the  aliBrite, as the Suzuki cases hate the shit of a stuff. Use paint stripper and a hand wire brush with a bit of good old fashioned elbow grease ;) and it will come up a treat.
Offline Doc
« Reply #4 on: September 28, 2014, 08:40:04 pm »
Degrease, 400 wet/dry wet on outer cases,  box or 2 of steelo soap pads for all over then metal polish and a liberal dollop of elbow grease :P
« Last Edit: September 28, 2014, 08:43:25 pm by Doc »
« Reply #5 on: September 28, 2014, 09:04:20 pm »
"Degrease, 400 wet/dry wet on outer cases,  box or 2 of steelo soap pads for all over then metal polish and a liberal dollop of elbow grease"
OK Doc now show us a piccie of the same bike afters ya cleaned it up...... :P :P :P :P :-*
« Reply #6 on: September 28, 2014, 09:41:37 pm »
AliBrite.
Depends
It will attack zinc plated bolts, you would need to replace those with others or mask them off, plus if the alloy has a lot of zinc in it, it wont make the alloy very bright at all and at best you will get a dull/dark grey finish and not a bright silver finish like you would with blasting or polishing. I have never found it to work well on cast alloys that you want to leave bare. Works much better on extruded/sheet/tube alloy eg bull bars and tray tops on Utes/trucks etc.
I would be more inclined to use the Black & Gold steel wool soap pads from the supermarket with plain water once you have got all/any paint & grease off. Some suzukis from mid 70's have the centre cases clear painted over the bare alloy.
« Last Edit: September 28, 2014, 09:46:55 pm by LWC82PE »
« Reply #7 on: September 28, 2014, 10:34:00 pm »
Thanks for the info guys.
 When is a good time to drop this engine over Doc?  ;D
Offline Doc
« Reply #8 on: September 28, 2014, 11:20:23 pm »
 ::) once ya finished the polishing of course ;D
