Author Topic: Honda CR250 1976  (Read 13350 times)
Offline bazza
Honda CR250 1976
« on: September 22, 2014, 08:23:14 pm »
Does any one know a wide foot peg that will fit these bikes?
« Last Edit: September 22, 2014, 10:31:04 pm by bazza »
Embrace patina
Offline bazza
Re: Honda CR250 1976
« Reply #1 on: September 22, 2014, 10:29:32 pm »
 Does any one have standard front and rear sprocket size?
Std Main jet and pilot jet size?
Embrace patina
Offline g465b
« Reply #2 on: September 23, 2014, 10:23:10 am »
hi, 14/47 and #155 main,  #55 pilot.   cheers G.
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #3 on: September 23, 2014, 11:10:53 am »
Early YZ/WR Yamaha fourstoke pegs fit with a bit of grinding work. I had 2004 WR footpegs on my '74 elsinore.
« Reply #4 on: September 23, 2014, 12:29:21 pm »
I have plenty of engine spares for one of those, (probably a complete engine in parts). Was keeping them for prosperity, but that day is long past. Available to anyone interested.
Offline davidsonclan5
« Reply #5 on: September 23, 2014, 05:02:10 pm »
Big K I'm interested in the engine parts and a big thanks for assisting with that frame.
Rob
DAVIDSON'S MOTORCYCLE TRANSPORT
0405 838 583
[email protected]
Offline bazza
« Reply #6 on: September 23, 2014, 05:32:47 pm »
Need rear wheel and hub , also 1 x front fork chrome To get started, looking for right chrome before go XL forks way only if I have to
Thanks again.
Embrace patina
Offline bazza
Re: Honda CR250 1976 rear wheel help
« Reply #7 on: September 24, 2014, 02:00:51 pm »
 have found cheap NOS fork leg=1 problem solved
Does any one know if MR250 rear wheel same as CR for 1976? look the same,not sure of offset?
Embrace patina
« Reply #8 on: September 24, 2014, 07:38:13 pm »
MR250 is a cush drive hub.....probably a good choice for keeping the gearbox alive even if it is a bit heavier. Offset may be slightly different
( I don't think it is) BUT it wouldn't be that much different. At the end of the day, the same spokes will be used.
« Reply #9 on: September 24, 2014, 08:34:46 pm »
the mr is a solid hub no cush drive mt has the cush drive.i owned one but sold it to matcho mick.
mr250 rear hub part no
42601-357-030
 HUB, RR. WHEEL (NOT AVAILABLE)
1976 cr250 rear hub part no
42601-357-030
lots of cr250 parts fit mr250
gearbox the same but different ratios
best honda parts on web
http://www.westernhillshondayamaha.com/index.htm
jim
« Reply #10 on: September 24, 2014, 08:47:34 pm »
I stand corrected Jim........so offset should be pretty much exactly the same
Offline johnmcc
« Reply #11 on: September 25, 2014, 11:08:24 pm »
I thought VMX Racing listed wide pegs for the 76 CR250 ?
« Reply #12 on: September 26, 2014, 06:57:12 am »
I just use xl250 pegs not wider but longer
jim
Offline bazza
« Reply #13 on: September 26, 2014, 02:55:25 pm »
Johnmcc they do but out of stock
Embrace patina
Offline micks
« Reply #14 on: September 26, 2014, 06:01:10 pm »
remember elsie 125 saying that Honda cfr230 pegs may fit and where $60 the pair. check it may help
